Old 03-12-2016, 08:04 PM   #1
65chevysub
65chevysub's Avatar
72 tilt column b/u light connection
Hi everybody. I have a 72 tilt column in my 65 Suburban, and I want to hook my aftermarket backup lights to the nsw but there are no open terminals on the switch to hook to. Can someone help me with this? Thanks
65chevysub is offline   Reply With Quote
Old 03-12-2016, 08:45 PM   #2
SS Tim
SS Tim's Avatar
Re: 72 tilt column b/u light connection
Did you look at a schematic? They are in the FSM.
The Dark Green (75) is the feed from the fuse block and the Light Green (24) is the switched output to the locally grounded lamps.
SS Tim is offline   Reply With Quote
Old 03-12-2016, 09:06 PM   #3
chiefcfd
chiefcfd's Avatar
Is that a manual NSS? If so just change it out with an auto switch and be good to go.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 03-12-2016, 09:45 PM   #4
65chevysub
65chevysub's Avatar
I believe it's an auto nss. I had the column put in about 17 years ago. My backup lights are units I bought at Autozone and are run off of a rocker switch on the dash.
Old 03-14-2016, 05:27 PM   #5
hdff
hdff's Avatar
I agree with Tim, the greens are what you use
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
