Old 11-03-2015, 04:55 PM   #1
bradnree
parking brake levers in hub
are 1/2 ton and 3/4 ton parking brake levers in the hub the same fit in a 1967 2WD
bradnree is offline   Reply With Quote
Old 11-11-2015, 07:16 PM   #2
hangman
Re: parking brake levers in hub
my 1970 3/4 was missing one, could not fine one. ended up at the junkyard
found the lever off a 87 1/2 worked with a longer pin up top and I had to
grind a little dimple off the edge. but it worked
hangman is offline   Reply With Quote
Old 11-12-2015, 06:07 PM   #3
bradnree
Thanks....brad
