air compressor moisture seperator question
My compressor is in the house and my blast cabinet is in the garage so I have to run a line out. I get a LOT of moisture in the line probably from the compressor being hot and the lines being cold. I have a filter regulator at the compressor and a small moister separator about 25 feet from the blaster. I have to stop about every 15 minutes and empty the separator and take the tip out of the gun to get the wet sand out. Should I be using a bigger separator or maybe install another one on the blast cabinet? took all day to blast a bunch of parts and I'm looking for a better way.
66 shorty ![]() |
Re: air compressor moisture seperator question
having the compressor far away is good for condensing out the moisture, now you need to drain it
are you using a rubber hose or copper line from the compressor and how long is the line? easiest way is to have a reservoir before the the blaster with air in the side, air out the top and a drain valve on the bottom the reservoir can be anything; a couple feet of 1'' copper or many feet of 3/4'' copper copper is easy to work with solder the joints and the plethora of cheap fittings at home depot
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I'm using rubber hose. I just have a cheap separator from HF thats about 30 feet from the compressor. then it plugs into the separator then about 20 feet to the cabinet. Any suggestions for a good separator?
66 shorty ![]() |
If you're blasting then it's probably getting the whole system hot and the water can't condense out before it passes through your separator. We were having that problem especially in the summer. Had two water traps but we were still getting water through.
Built this to cool the lines off enough to condense the water out. Its a dorm fridge with a 5 gallon bucket of water inside, and 20 feet of copper tubing coiled inside of the bucket of water. The cold water cools the air line so that the water vapor can condense and be caught by the water trap on the outside of the fridge. I've got it connected with quick disconects so I can move it if I need to. Works great! ![]() ![]() ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I had an 80ggallon compressor and ran it into a dead 29gallon compressor right b4 my blast cabinet and that solved all my condensation problems being less than a quarter mile from the ocean and high humidity it was quite moist and that solved the problem'
I could blast all day long without problems as long as I used dry clean media/// not playsand cause that attracts moisture and you buy it wet// bagged steril is the way to blast for the few extra bucks
![]() Join Date: Mar 2013
Here is the setup in my current makeshift shop area. Used black pipe with drops and ball valves for drains on all vertical runs. Also note that the horizontal runs are on an angle running towards a drain. The main feed line to my air tools goes up and around (above the '76 MI license plate) so that the condensation is directed towards the drain and not the tool. The black pipe helps cool the air and therefore works to turn the condensation into liquid that can be drained. I have an outlet plumbed for adding a water separator at the end of the run if needed.
+1 for the black pipe setup, below is a picture of my setup. i've painted in 95*+ heat and 70% humidity with zero problems.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
