Location: Stoughton MA where everyhing on the road gets rusted out from winter and rock salt
How the heck do you put on Po3 Caps with out dents
Just about ready for winter New Tires Rear Shocks waiting for front to arrive, Got rid of ford hub caps that where on the rear So how the Heck do you get these p03 Hub caps on with out denting them
Re: How the heck do you put on Po3 Caps with out dents
and the Running boards are back on Happy birthday to the Mrs.
![]() Join Date: Oct 2012
Subscribed, I would like to know too, if there is a proper technique.
Also, that olive truck looks sweet.
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" |
#4 | |
gg |
Go Pack Go!
I put mine on by getting one side under the nubs and while holding in place used the heal of my hand giving the other end (near the outside edge of the cover) a couple good hits. Once set in place, I used the heal of my hand around the outside edge of the cover to make sure it was seated good. A rubber mallet works good too, but I don't have one.
Moderator
![]() Join Date: May 2007
I use the bottom of my fist and the palm of my hand. If they need more force, I put a thick rag over the edge and use a rubber mallet.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
I got one of those hub cap tools with a rubber bumper and still dimpled them a little, I guess I'll use my hand and keep practicing maybe put a little lubricant on next time the caps are Old and pretty beat already I wouldn't want try it on any nice ones at this point
If the wheels are painted I use my hands to install and a Snap-on hubcap hammer to remove or if the wheels are coated I use the hammer to install and remove.
Here is what the hammer looks like. Is hammer will work up to the 9 3/4 wide wheels.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Just have to stay on the very edge where it's stiffest. But if they've been dented before they'll dent real easily again.
I think that's my problem They were in bad shape to start, But It looks good from 20 ft I put on tiers and shocks all around Spring asst shocks in the front and air shocks in the back so I can a just for trailer use I very Happy with this truck
Looks great.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
X2, this is the only damage free method. If does not pop on easily, spin clock wise or counter clock wise till the best fit is attained. These original PO3 are notoriously weak, they are chrome over brass construction, they dent, split, crack very easily. GM finally wised up and started making these caps out of stainless. Truck looks great, very difficult to improve on the "factory look" .
![]() Join Date: Sep 2005
Mine have cracks in them, so they are pretty easy to remove. Works out kind of nice, actually, since they have enough "catch" that they stay on when driving, but come off/install pretty easily.
![]() Join Date: Oct 2009
Hook cap around a nub, then on the other side of the diameter of the cap, spread load as much as possible around the outermost rim of the cap with your hand (I just use thumb and heel of the hand) and, while pushing across the cap at the hooked nub (most important part is to keep it pressed tight against the nub by pushing ACROSS the cap, not down toward the wheel face), push down with the spread load of the hand on the other side of the cap. This is the best success I've had and it's still not perfect.
#15 | |
![]() Join Date: Jan 2012
#16 |
I use non metallic scrapers and pick a spot that has a small gap, keep the ends sharp. Harbor freight sells a complete set.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#17 | |
