Old 09-17-2003, 11:09 AM   #1
beeroh
What MPG should I be getting?
What MPG should I have 4X4 longbed with 33" tires 4.56 gears w/posi and 700R4?
84 Silverado,
beeroh is offline   Reply With Quote
Old 09-17-2003, 11:31 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you are lucky, you will break past 10mpg. More realistically expect about 8-10. After some tuning, it might get 12, but that is about the max for a 4x4.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-18-2003, 05:53 PM   #3
apstguy
LED King
apstguy's Avatar
what engine? - BTW why do you have different gear ratios from front to back? that is very bad for the 4X4 system.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 09-18-2003, 09:59 PM   #4
beeroh
I have 3.07 in the front
4.56 inthe rear
wuz up
84 Silverado,
Old 09-19-2003, 03:42 AM   #5
Nvbowtie
Nvbowtie's Avatar
4.56 inthe rear
wuz up
Hmmmm May be someone switched one of the axels ?? I always thought they were to be matching ratios, otherwise the odd tire rotation would be hard to control on steering
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 09-19-2003, 04:40 AM   #6
beeroh
drove 107 miles and filled up 8gallons. = 13.375 mpg
to bad the speedo is off and not adjusted for my setup
so I am probably doing more like 10mpg
84 Silverado,
Old 09-19-2003, 09:41 AM   #7
Captkaos
Captkaos's Avatar
4.56 inthe rear
wuz up
I hope you are not using 4 wheel drive in this thing, EVER! You can tear something up for sure if you do. You are putting undo stress on the drivetrain and this can pop a spider gear, u-joint or damage the transfer case. You REALLY need to address this issue. Ratio variance front to rear should be no more than 1% for the street and 2% for offroad.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 09-19-2003, 01:24 PM   #8
beeroh
I had a friend of mine check it out for a few feet,
when I noticed the back tires skipping, I told him to stop
and get out of 4X4 mode.
sucks that I can't use 4x4, waiting and hopeing the guy that sold
me the truck will fix the problem
84 Silverado,
