Old 11-25-2015, 02:07 PM   #1
davepl
davepl's Avatar
Factory big block throttle, return, and PCV
Does anyone have a picture of an original PCV setup for a big block (1970 if it matters)?
Mine uses a straight PCV, not a 90, so the hose sticks way up and the wraps around to the carb; that's how it was when I got it, and the truck was largely unmolested except for carb linkage.
Also, does anyone have a good picture of the clip used to hold the throttle rod to the carb? I've just got a cotter pin through it and suspect that's not original.
Same deal with return spring.
I guess I'm asking "Does anyone have a good photo of a stock big block" with these details visible?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-25-2015, 02:48 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Factory big block throttle, return, and PCV
these are a 72 so they sound different than yours.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-25-2015, 03:15 PM   #3
michael bustamante
michael bustamante's Avatar
throttle rod to carb is just held in with a small cotter pin
1967custom
michael bustamante is offline   Reply With Quote
Old 11-26-2015, 05:02 AM   #4
Aus69c20
Aus69c20's Avatar
Here's some pics of my 69. the throttle linkage is retained by a split pin. On mine anyway.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 11-26-2015, 11:06 PM   #5
71 super
71 super's Avatar
The correct pcv hose has a molded 90* angle so it works correctly with the straight pcv. Split cotter pin is correct for bob linkage, return spring attaches to kick down bracket at rear of carb- should be a hole that the springs attach to. The throttle rod was the reason for the stop lifts equipped on many of the pre 71 trucks, the motor mounts would break on driver's side pinning throttle wide open and causing a wreak. Hence the reason to transition to cable in 71.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-27-2015, 02:38 PM   #6
davepl
davepl's Avatar
So to reassert what I think I've heard, for my 1970:
- Split pin/ cotter-pin correct, maybe with a washer
- Single spring from linkage to lift hook in front of carb
Any idea on single/double, style, color, or pic of the return spring?
