Old 06-18-2015, 08:58 AM   #1
drumyn61
What year is my truck?
The title says 1960 but I feel like it's a 62!
drumyn61 is offline   Reply With Quote
Old 06-18-2015, 09:02 AM   #2
drumyn61
Re: What year is my truck?
pics
Old 06-18-2015, 09:13 AM   #3
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
What is the vin number and does it match the number on the frame on left side located on top of the frame about the front of the engine?
66Gilbert is offline   Reply With Quote
Old 06-18-2015, 09:27 AM   #4
62 Barnfind
62 Barnfind's Avatar
Here is a decoder. Sorry I cut it off but you can check your first number and see what year it is. I hope this helps you.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 06-18-2015, 09:48 AM   #5
drumyn61
numbers
Old 06-18-2015, 09:48 AM   #6
TJ's Chevy
TJ's Chevy's Avatar
Has the wrong year hood on it for sure. That hood is from 62-66. That's a common swap. Yours is either a 60 or 61 due to the double headlight grill. 62 had single head lights and "oval pod housings" for the headlights.
EDIT: Checked the vin...you have a 1960.
Old 06-18-2015, 09:52 AM   #7
drumyn61
But I think the emblem on the cowl extension is a 62, right? So did they change that out as well? Maybe they added it when they repainted it.
Old 06-18-2015, 09:55 AM   #8
62 Barnfind
According to the decoder it's a 60 because of the 0 in the vin. Like TJ said, you have a 62-66 hood and 62 badges on the side. If you want to go back to the original look you won't have to change much. I still thinks it a cool truck! Whats your plans?
John Z
62 Barnfind
Old 06-18-2015, 09:56 AM   #9
TJ's Chevy
TJ's Chevy's Avatar
Those are 62 emblems. 60 emblems are fairly tuff to find I think. They make 1/2 ton ones brand new. What's yer plans for it? What ya got for a drive train?
Another thing I noticed...that is not an all original truck. According to the vin decoder your cab vin states its a 1960 1/2 ton shortbed 2wd. Looks like someone has done a cab swap in the past.
Old 06-18-2015, 10:07 AM   #10
62 Barnfind
I saw that to TJ.
John Z
62 Barnfind
Old 06-18-2015, 10:19 AM   #11
drumyn61
Is it a cab swap or a Napco 4x4 chassis? Did Napco have any ID#'s
Old 06-18-2015, 10:21 AM   #12
drumyn61
I found a good solid 60 hood locally and I'm going to swap it out.
Now that I know it's a 60', I'm going to change the emblems and add some better mirrors and stock wheels and hub caps and DRIVE THE CRAP OUT OF IT!!
Old 06-18-2015, 10:39 AM   #13
66Gilbert
66Gilbert's Avatar
The frame number does not match the cab vin tag it should be stamped J104591 the cab was put on this frame at some point. The cab vin tag looks to be original and not altered, it says it is a 1960.
Old 06-18-2015, 11:36 AM   #14
66Gilbert
66Gilbert's Avatar
Also forgot to mention the cab is from a 2WD drive truck. The original 4x4 cab must have possibly been wrecked or badly rusted.
Old 06-18-2015, 11:49 AM   #15
drumyn61
You may be right, if they swapped it seems like it was a long time ago with all of the dirt and grim on it.
Old 06-18-2015, 12:59 PM   #16
61K10
61K10's Avatar
frame looks like my 61. 60-62 frames are the same. they changed the front shock mounting in 63? maybe late 63. rear shock mounting also, don't know what year. (ron you out there)about the vin the c would be a k if the cab came off a 4x4.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-18-2015, 02:44 PM   #17
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
According to the preliminary information booklet, the 4wd lever was on the passenger side of the 4 speed shifter, 1962 was on the drivers side of the 4 speed shifter.
Napco's 4WD were on the right as well.1960 was the first year for GM in house production of light duty 4WD in 1/2 and 3/4 tons, no 1 ton 4wd were produced by GM
The Vin should have a K as a model designation if it was a factory 4WD. It was still optional for a customer to request a Napco conversion which would have been a C ( Conventional ) designated cab.
The inward mounted rear shocks were standard till 62.
Old 06-18-2015, 04:45 PM   #18
oldusafmsgt
oldusafmsgt's Avatar
It's a 60 cab for sure, other is mix of 60-62 parts.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 06-18-2015, 10:58 PM   #19
jtrichard
clean up the rest of the frame vin and take a pic then we can figure out what year the frame is
jtrichard is offline   Reply With Quote
Old 06-19-2015, 12:03 AM   #20
drumyn61
I'll clean it in the morning at get a better picture but it ;looks like the number is: J115321
Old 06-19-2015, 12:10 AM   #21
jtrichard
Should be 5 more in front of that ... the J says it was built in the JANESVILLE plant
Old 06-19-2015, 12:14 AM   #22
66Gilbert
66Gilbert's Avatar
Nope only the last seven of the vin number is stamped in to the frame.
Old 06-19-2015, 12:14 AM   #23
drumyn61
aaaaaaaaaah.
Old 06-19-2015, 12:26 AM   #24
71swb4x4
71swb4x4's Avatar
You might have a 1962 SWB 4x4 that had a 1960 cab swapped on for some reason. Hard to say. Not too sure I would care. Might get the frame and cab VIN straightened out at the DMV to make sure nothing is stolen, wash it up, and drive the wheels off it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-19-2015, 01:31 AM   #25
drumyn61
It does look like both frame and cab vins are made in Janesville.
I sanded down the frame and didn't see any other numbers.
