Old 03-25-2014, 12:16 AM   #1
Hatzman
Hatzman's Avatar
LS conversion - fuel delivery system - options?
So parts have been ordered for my 1970 C10 ( build thread below) and I am onto my next step!
Fuel delivery system...
I already have the rear mount gas tank and that's in place.
My plan is to purchase the Aeromotive A1000 fuel pump (researching if it can be mounted inside the tank), and I'm up in the air about regulators.
What's your fuel system made up of and how well do you like it?
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-25-2014, 09:23 AM   #2
Ridgeclimber
Re: LS conversion - fuel delivery system - options?
It depends on what you have on the engine you are installing. When I installed my LQ9 LS 6 liter I used the the fuel pump in a Boyds gas tank. Then just ran a pressure and return lines through a filter and to the manifold. There is a fuel regulator on the fuel rail. Or you could use a corvette fuel filter/regulator then just run one pressure line up to your one line fuel rail system, no return line.
Ridgeclimber is offline   Reply With Quote
Old 03-25-2014, 10:24 AM   #3
Hatzman
Hatzman's Avatar
The LS i'm using is the LQ9 out of a 2004 Escalade and im going to keep the stock EFI system.
Ridgeclimber, what year corvette?
Steve
Old 03-25-2014, 11:12 AM   #4
trkfrk
trkfrk's Avatar
Subscribed
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 03-25-2014, 11:34 AM   #5
Ridgeclimber
That is the same engine I used, but I changed the intake and fuel system to the older drive by cable throttle body with two fuel line system. Just because that was the fuel system and engine harness I had in the truck on the first engine that I installed. I originally installed a 4.8 liter first which ended up being total junk, so then I found the 6 liter. If I remember correctly that LQ9 had a drive by wire throttle body and one fuel supply line. You will be very happy with the performance and drive ability. I also installed a 4l60e trani, with the 3.73 posi. Works good. I'm not sure when the corvettes started using the filter/regulator assembly. I'm guessing 2000 and newer, any one with the LS engine.
Old 03-25-2014, 11:49 AM   #6
Matt Cramer
An A1000 is a lot of pump unless this is a seriously modified engine. I have a 255 gph Walbro stuffed in the stock fuel tank and a stock return type fuel pressure regulator myself.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 03-25-2014, 12:03 PM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
Fuel system stuff has been discussed ad nauseam in the LS swap section.
http://67-72chevytrucks.com/vboard/s...d.php?t=620218
http://67-72chevytrucks.com/vboard/s...d.php?t=349201
http://67-72chevytrucks.com/vboard/s...d.php?t=566743
http://67-72chevytrucks.com/vboard/s...d.php?t=549571
http://67-72chevytrucks.com/vboard/s...d.php?t=607440
http://67-72chevytrucks.com/vboard/s...d.php?t=605781
http://67-72chevytrucks.com/vboard/s...d.php?t=604878
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-25-2014, 06:47 PM   #8
Hatzman
Hatzman's Avatar
Wasted Income is such a buzz kill.
Thanks for the multiple links!
Steve
Old 03-25-2014, 08:31 PM   #9
thump426er
Edelbrock makes the Universal Fuel Reservoir kit which you can just feed with as little as a regular mechanical pump and it'll deliver a constant 60psi, not sure what the system you have needs though.
thump426er is offline   Reply With Quote
Old 10-26-2016, 07:34 PM   #10
elf w/capital T
what did you end up going with?
elf w/capital T is offline   Reply With Quote
Old 10-26-2016, 09:47 PM   #11
davepl
davepl's Avatar
I run an A1000 in-tank for my LS3.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-27-2016, 06:37 AM   #12
This is a topic for the LS Swap section. Did yu know about that?
