Old 12-24-2015, 09:01 AM   #1
Cannoncollector
H072 rear ring and pinion will need 4.10 have available 6.17
I'm looking for information on my rear to swap out the 6.17 s for maybe a 4.10 ratio, I've been told its a h017, my truck probably only has 57,000 on it so it's gears should be nice!
Cannoncollector is offline   Reply With Quote
Old 12-24-2015, 04:04 PM   #2
cypressbog
Go Pack Go!
Re: H072 rear ring and pinion will need 4.10 have available 6.17
Find any center chunk from an HO-52 or HO72 that has the 4:10 gears, pull your axles out 5" unbolt old and install new one. You can convert to disc brakes too fairly easy. I seen a how to post of Stovebolt: http://www.stovebolt.com/techtips/ax...Ton%20Upgrade/
cypressbog is offline   Reply With Quote
Old 12-25-2015, 11:02 AM   #3
Cannoncollector
Ok thanks, so the 52 is the same pumpkin?...axles?...what is the difference between the 2?...thanks alot!!
Old 12-25-2015, 11:41 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Just a heads up you have to be a "Premium" member to buy, sell, or trade parts on the board. (name in Blue) If you click on the word "Subscribe" in the menu bar above it will explain the different options.... If you find something that someone is selling in the classified forums you can buy it without subscribing, you just can't post a WTB, WTT, or FS.
LockDoc
Leon
Old 12-25-2015, 11:53 AM   #5
Cannoncollector
LockDoc
Oh ok, let me check that out, thanks
