Old 01-08-2016, 12:11 AM   #1
Libertys36
1967 to 1969 GM Tilt Column Parts Diagram
Does any of the forum supporters have a detailed diagram of what parts are in the 167 to 1969 GM Tilt columns. I would like to know what parts are suppost to go where, in rebuilding / repairing the column in my truck. It's for an automatic transmission, (350 v/8, with auto), has tilt, has flasher button on lower right side, and does not have the column mounted ignition key. This is an early column, and I believe some parts are missing from previous attempts to fix/repair. I'd like a diagram to go by but can't locate one with good image and parts break down. So, if there is a diagram/image out there and you would like to help a fellow 67/69 Chevy pickup person, much appreciate your assistance. If anyone has a spare "quadrant light and light bulb cover" I would appreciate a spare as one is needed. The Quadrant light is the small glass bulb light that is deep inside the column that is used to light-up the shift indicator bar so that one can tell what gear the column shift is currently in when it's dark inside/outside. (other than moving forward, backwards or just not moving!)
Libertys36 is offline   Reply With Quote
