Old 04-06-2002, 09:59 AM   #1
67Blacksheep
Post Will 2000 GM wheels fit 67-72 6 lug pattern??
Gentlemen-
Will the more modern...say 2000 6 lug GM truck wheels fit on our 67-72 six lug trucks. I measured mine at a 5.5 pattern. Up to what year will bolt up?? Any that I should stay clear of?? Thanks.
67 Chevy C20 LB Stepside,
350 4-bolt with goodies.
'94 GMC Seirra Ext. Cab
'67 Formula Firebird
'89 GSX-R 750
67Blacksheep is offline   Reply With Quote
Old 04-06-2002, 10:25 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Post
Blacksheep,I beleive this question was asked but if I remember right the center spindle hole is smaller on the later wheels.You might want to check before you drop the $$$ for wheels.
Deland does Chevys 68Chevy panel(LIZ)
"A man and his truck,it's a beautiful thing"
"I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-06-2002, 10:47 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I have a friend who tried to put oem wheels off a 93 onto his 76 4X4, the centers of the wheels were too small to fit over his hubs.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-06-2002, 12:33 PM   #4
Als454
Post
I put a set of 97 rally rims on my 69 C-30 frame. Had to replace all of the studs with 14mm after that they fit perfect.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
3" Exhaust W/Headers
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 04-06-2002, 01:20 PM   #5
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Just don't try to use any late model Ford wheels, they are metric. Another one of Ford's better Ideas, screw up the system that has been in place for 40 years.
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
Old 04-06-2002, 02:36 PM   #6
Alexis
Member since 2000
Alexis's Avatar
Post
i have seen a our trucks with 2000 wheels on them, the center hole thing is huge compare to our trucks. they stick in thw wheel well so dont look to great.
Mechanic @ California Concept
Britney: 1970 2wd K/5 Blazer (Frame up)
Jessica: 1967 2wd SWB (pops daily driver)
Helga: 1972 4x4 3/4ton LWB (my daily driver)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
Old 04-06-2002, 08:05 PM   #7
67Blacksheep
Post
Thank you-
I was looking at a set on e-bay, but sounds as though I better hold off or buy new six lug rims from Jegs. So much for saving a buck, huh?
'89 GSX-R 750
Old 04-07-2002, 01:35 AM   #8
primer67
primer67's Avatar
Post
I tried '98 Tahoe ralleye rims -- perfect fit
just heavy as heck.
primer67 is offline   Reply With Quote
Old 04-07-2002, 03:59 AM   #9
dmnall
dmnall's Avatar
Post
Actually the 6 lug wheels off the 1999 and up Chev Silv./GMC Sierra's will not work 67 - 72 6 lug trucks because of the center hole is too small, but w/ a modification of the of hole, then it will fit on to the Hub, but other then just modifying the hole on the wheel itself, the bolt pattern is the Same!! I know, my dad was given an extra set of Wheels off of his neighbors 2000 Silverado, and I tried to put them onto my 68 Chev and my hubs were too large!!
Truck #1 68 Chev LWB Fleet w/ Wood Floor (Sucks Gas and Hauls Ass!) and in process of Body Work...
Truck #2 1994 GMC Sierra SL w/ 4.3L Vortec V6, 4L60E Auto!!
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
Old 04-07-2002, 06:28 AM   #10
Blazer1970
Blazer1970's Avatar
Post
The bolt pattern is 6 on 5 1/2, just like all GM 6 lugs, but any '88 and up truck wheel has 5 1/2" backspacing instead of the 3 1/2" that was used until '87, including the '67 - '72 era. This will move the tires 2 inches farther into the wheel wells. Would not look good, imo.
Blazer1970 is offline   Reply With Quote
Old 02-04-2015, 03:44 PM   #11
SHOCKER1
Re: Will 2000 GM wheels fit 67-72 6 lug pattern??
Can't I get around the larger hub on my 68 and the backspacing issue by installing a 2" wheel spacer? what are your thoughts?
SHOCKER1 is offline   Reply With Quote
Old 02-04-2015, 03:55 PM   #12
michael bustamante
michael bustamante's Avatar
any one know of a way to widen the center holes on newer chevy 6 lug wheels? other than a lathe i mean. like a way we can modify using home power or hand tools?
1967custom
michael bustamante is offline   Reply With Quote
Old 02-04-2015, 05:30 PM   #13
67 cst swb
67 cst swb's Avatar
My opinion?
The backspacing issue is the killer for me.
My thought is, if you have to run an adapter or a spacer for a wheel to work, it's not the right wheel for the vehicle.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-04-2015, 07:28 PM   #14
HSRACER
HSRACER's Avatar
Originally Posted by 67 cst swb View Post
My opinion?
Times 2!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 01-05-2016, 02:15 AM   #15
val durio
The newer trucks..88 and up have a different off set and back spacing..and the diameter of the center is smaller..on a 67-72 the wheels will sit way in the wheel well so it's not worth Maki g the hole bigger for an ugly look..
val durio is offline   Reply With Quote
Old 01-05-2016, 10:21 PM   #16
sapper4
The wheel offset from new rims to old spindles will allow them to fit with custom spacers, which will also fix the hub bore issue. I had a set made from motorsport-tech.com. I am doing the same thing. They are a bit pricey at $285 though.
sapper4 is offline   Reply With Quote
Old 01-05-2016, 10:28 PM   #17
tcrist
You can check here, http://adaptitusa.com/6-lugto6-lugadapters.aspx
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 01-06-2016, 05:24 PM   #18
lutronjim
I like the looks of the 2000 chevy truck wheel. I am converting to disk brakes on front of my 70 C10 by installation of a later model 'K' member and was thinking like 67blacksheep.
I am adding a conversion rotor to keep 6 lug up front.
Does anyone know of an aftermarket cast wheel that looks like the 2000?
lutronjim is offline   Reply With Quote
Old 01-06-2016, 06:53 PM   #19
RussellRay
67blacksheep I know the wheels you are looking at might be different from these, but to get these to fit we bought 6 lug wheel spacers found here
http://www.ebay.com/itm/6x139-7-to-6...-/181035692411
might not be the right ones for you, just need to measure them. they bolt on to your existing lug nuts then we just bought 2000 Tahoe lug nuts to screw on the center caps
RussellRay is offline   Reply With Quote
Old 01-06-2016, 06:54 PM   #20
RussellRay
we also have drop spindles and front disk brake conversion
Old 01-06-2016, 07:43 PM   #21
michael bustamante
and you wanna know what i found out the hard way????? you cannot use older 15 steel wheels like rallys on the newer 6 lug pattern!!! the calipers hit the rim!!
1967custom
Old 01-08-2016, 03:23 AM   #22
89AKurt
89AKurt's Avatar
Good, I was considering this, but stupid idea knowing about the backspacing.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
