4"drop from a 3"spring
How much do I cut off of a 3" drop spring to get 4" drop?
![]() Join Date: Dec 2013
Re: 4"drop from a 3"spring
That's going to be a hard question to get answers on .It's like asking what color is white ? Different manufactures ,Varying spring tension and no one wants to give you an unintentional misleading measurement at best it's going to be a guesstimate .
laying low
![]() Join Date: Mar 2001
If removing 1 coil on a stock spring nets about 2" then a 1/2 coil should net about 1" approximately.
However, the general line of thinking is that going with any more than a 3" spring drop only on front leads to alignment issues. The better approach is 2 1/2" or 3" dropped spindles + 1, 2" springs.
When you say "drop only on front", if I'm dropping the back 5", will that help me on alignment
![]() Join Date: May 2014
He means drop spring. You're better off doing a spindle drop or a spindle/spring combo to get your desired amount of drop.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
........and get ready for most likely a lousy ride....
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
