Old 01-23-2016, 11:04 PM   #1
smittster
gas sludge removal in aluminum tank
My truck sat for 3 years. I have an aluminum tank under the bed. The tank has a drain plug. Removing the tank would be the very last resort. I drained the old gas and can see some slugde in the tank. What can I pour in the drain and rinse to get this stuff out? I have read about muratic acid, acetone, kerosene, any suggestions?
smittster is offline   Reply With Quote
Old 01-24-2016, 12:35 AM   #2
Foot Stomper
Foot Stomper's Avatar
Re: gas sludge removal in aluminum tank
I'd add 5 gallons of fresh gas, a healthy serving of fuel stabizer, a fresh in line fuel filter and drive it till empty.
Add fresh gas and cruise... Have replacement filter handy until confident.
Fuel stabilizer goes into every gas tank in the fall except daily driver in my stable.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 01-24-2016, 09:58 AM   #3
1project2many
Acetone is good for dissolving some types of sludge but it's not nice to paint. Today's E10 gas will loosen a lot of junk from an old tank. Stabilizer is a great idea as fuel today starts to oxidize quikly.
1project2many is offline   Reply With Quote
Old 01-24-2016, 11:10 AM   #4
Rickysnickers
Rickysnickers's Avatar
I know you said it was your last resort, but I think I would be inclined to pull it and clean it out properly. If you can see the sludge in there, you probably won't be able to tell how much is in there. I wouldn't want to risk ruining anything by just using stabilizers and filters.
Old 01-24-2016, 01:54 PM   #5
smittster
Ok, I am taking this advice now, thanks. How would you recommend I clean it out when I remove the tank?
Old 01-24-2016, 04:43 PM   #6
mr48chev
mr48chev's Avatar
I've pressure washed a number of gas tanks out over the years. I usually pulled the sending unit out for access to the inside of the tank and then flushed it out.
I threw the stock tank from my 71 GMC that had sat for years on end away because it had too much crud in it to clean out though. It has a 30 gallon stainless tank in the front of the bed that now needs cleaned as it has sat for that three or so years without stabilizer in it after I blew the 350 in it.
Don't put fresh gas in it and run it as that crud will end up coating your exhaust valves and harden when the engine cools and then you have to tear the engine down. That's from first hand experience.
My ongoing truck projects:
