Old 02-01-2016, 10:57 PM   #1
poco64
frame paint ?
Ok so i have all the body stripped off my frame should I sandblast and epoxy primer and then paint or power wash, convert the rust and use por brushed on a couple of coats and then paint? thanks a bunch for any advice.
poco64 is offline   Reply With Quote
Old 02-01-2016, 11:05 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: frame paint ?
Media blast if possible.
POR15 brushed as thin as possible X 2 coats
When the final coat of POR15 is nearly dry (like 99% dry) spray a top coat which can be rattle can. Just my 2 cents.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-01-2016, 11:10 PM   #3
suburban99
suburban99's Avatar
Re: frame paint ?
I used chassis saver on mine...looks good and lasts good..
suburban99 is offline   Reply With Quote
Old 02-01-2016, 11:34 PM   #4
ol_skool_chevy
ol_skool_chevy's Avatar
Re: frame paint ?
From what I understand POR15 have no UV protection .....be warned
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-01-2016, 11:42 PM   #5
Lugnutz65
Lugnutz65's Avatar
Re: frame paint ?
That is correct. POR15 will fade if exposed to UV light. That is why top coating it is important. I used a Rustoleum high temp spray rattle can paint. I chose low gloss black.
Old 02-01-2016, 11:44 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: frame paint ?
http://www.rustoleum.com/product-cat...h-performance/ Check out some of these. You can get most of them at your local Home Depot. I used rustoleum on my frame and it has held up well the past 15 years. I bought the Gal and used a spray gun to apply. Primer underneath.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-02-2016, 12:03 AM   #7
Heater63
Heater63's Avatar
Re: frame paint ?
Sandblast- will remove 99% of all rust
Use some Ospho (phosphoric acid) on any remaining rust / pits
Prime with epoxy primer
Topcoat
292 + TKO500
Heater63 is offline   Reply With Quote
Old 02-02-2016, 12:49 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
Re: frame paint ?
I sanded mine to bear metal, epoxy primed and then top coated with black single stage. 3 coats of primer and 3 coats of paint.
Old 02-02-2016, 12:56 AM   #9
60chevyjim
60chevyjim's Avatar
Re: frame paint ?
sand blast it and paint it with semi gloss rustoleum paint .
stand it up on its side to sandblast then switch to the other side to get the spots u missed .
paint it with it up on its side then switch to the other side to finish it .
> epoxy primer is only a primer , it's not a finish coat <
this chassis is for my friends 65 chevy c10 long bed that im doing for him.
60chevyjim is offline   Reply With Quote
Old 02-02-2016, 09:33 AM   #10
Marv D
Registered Truck Offender
Marv D's Avatar
Re: frame paint ?
Just a mention.... Rustoeum 'SATIN' black looks very very close to the original low-gloss lacquer the factory used on frames and underhood.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-02-2016, 10:09 AM   #11
The1960APE
The1960APE's Avatar
Re: frame paint ?
Add a vote for POR15 with a top coat....a lot of the time I don't even top coat, how many of our frames see direct sunlight? that's like waterproofing your bedroom ceiling.... LOL
The thing about POR15 is that its tough, really tough stuff and holds up to gas, oil, antifreeze etc!
I once done a set of fender wells with a rattle can paint, about ten coats, cut, buffed, rubbed etc. They were a real showpiece! until the very first time I had any type of antifreeze leak, it really damaged the finish.
That was my LAST time using a rattle can for anything, it is just not made for longevity or durability if you are against using POR-15 I would powder coat or get a gallon of professional chassis paint and learn to shoot it!
Doing all that hard work to a gorgeous truck just to have frame paint issues a year down the road because you rattle can painted the chassis is a shame and certainly a major pain to go back and do right once the truck is assembled.
The1960APE is offline   Reply With Quote
Old 02-02-2016, 11:38 AM   #12
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: frame paint ?
I would blast and epoxy prime, then paint over it. POR15 doesn't always do well on clean metal. It actually wants rust to stick to. That is what POR stands for, Paint Over Rust. I have seen POR15 peal off from clean metal.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-02-2016, 03:20 PM   #13
Rust-O-Matic
Rust-O-Matic's Avatar
Re: frame paint ?
I sandblasted mine, then two coats of POR 15, then 2 coats of satin black Vansickle tractor paint from Orscheln's. Once dried, it's crazy tough. Like sledge hammer tough.
I took the lazy way out on the '66 I'm currently working on, and brushed a heavy coat of that same Vansickle right over the pressure washed (but still rusty) frame. It actually looks way better than I expected. We'll see how long it stays on there...
Rust-O-Matic is offline   Reply With Quote
Old 02-02-2016, 07:58 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: frame paint ?
Thats one easy to paint the frame on all sides.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-02-2016, 08:51 PM   #15
60chevyjim
60chevyjim's Avatar
Re: frame paint ?
I am doing everything by myself , im 59 I use the engine lift for a helper.
I power washed it with it up on its side using diesel fuel then purple power .
then I grinded as much as possible with my 4 1/2" angle grinder and a cutoff wheel for a grinding disc. this way there was way less to have to sandblast ,
it's very quick and ez doing it this way..
spray painting it was very ez this way and it cost less than $50.00 to paint everything ..
I bought a gallon of flat black rustoleum , and 1 quart of gloss black rustoleum and a quart of acetone to reduce it.
I sprayed everything flat black on all sides . with it up on its side and then I dropped it back on the wheels to finish the first coat. the next day I lifted it up on the opposite side.
and I mixed the quart of gloss black with the 2 quarts of flat black that I had left
and sprayed all sides of the chassis then dropped it back on the wheels and finished it.
this truck is going to be a driver and my friend had not even thought about painting the chassis. that was my idea .
Old 02-02-2016, 09:51 PM   #16
DakotaKid
Re: frame paint ?
Por 15 will stick to clean metal just fine as long as you follow the instructions. People think that they can just paint over the rust with it, and it will work that way, but the best way to get adhesion is to use their metal prep, or something like Picklex. I have never had Por 15 fail on something that I have used their prep system with.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 02-02-2016, 11:47 PM   #17
BigDan3131
BigDan3131's Avatar
Re: frame paint ?
Blast it and if the weather holds epoxy it but rather than putting two coats of this and two coats of that order this from Amazon: http://www.kilz.com/hammerite/v/inde...008a05d103RCRD it comes in many colors but the real reason to use it isn't printed on the label anymore. It contains ground glass and aluminum and once fully cured is a very tough industrial enamel. Rustoleum is a fish oil based product and can only be coated with other Rusto products. I have been using Hammerite for well over 15 years in both the fence business [where it was subjected to saltwater mist] and the car business painting all suspension part. If there is any rust it traps it in place and seals it away. Its so tough that on a budget I painted a whole truck with it, let dry, sanded it and cleared it. You can't even tell its not automotive grade paint.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-03-2016, 02:17 AM   #18
60chevyjim
60chevyjim's Avatar
Re: frame paint ?
here is my 93 gmc 454 tow wagon that I painted for less than $75 using a gallon of red and 2 quarts of black rustoleum and a harbor freight spray gun . I painted it outside last year. I am on a very limited income . so this was the only paint i had enough $$ to buy ..
when I was working I would never paint a car or truck with enamel ever .
i figure if it looks this good on my truck , its good enough for a chassis that no one will even see.
Old 02-03-2016, 08:02 PM   #19
61_FL_Apache
Who Me?
Re: frame paint ?
Great truck!! I like the Impala SS wheels..
Steve
2001 Blazer 4D 2WD
Old 02-03-2016, 10:18 PM   #20
dracko
dracko's Avatar
Re: frame paint ?
Another vote for Chassis Saver, really like the antique satin black. stuff goes on nice, even decent with a brush and cures rock hard.
dracko is offline   Reply With Quote
Old 02-03-2016, 11:28 PM   #21
60chevyjim
60chevyjim's Avatar
Re: frame paint ?
thanks !!
the truck was just a flat black rolling body that I rescued before it went to the crusher.
I put it together for a few hundred bucks using parts that I all ready had like the 96 impala SS rims and the 1975 454 with a fresh rebuilt th350 .
Old 02-04-2016, 12:23 AM   #22
andyh1956
Re: frame paint ?
Big Dan did you use the smooth or the hammered finish? In the smooth they don't have a semi gloss black, just a gloss & flat. I spose I could mix both for semi
andyh1956 is offline   Reply With Quote
Old 02-07-2016, 03:12 AM   #23
Mtl-Marc
Re: frame paint ?
Topcoat
This.
Mtl-Marc is offline   Reply With Quote
