Old 02-14-2016, 06:11 PM   #1
mobileortho
mobileortho's Avatar
MMll power rack question
The hose kit for my power rack included these brass fittings. The instructions say they're supposed to go into the ports on the rack if the rack didn't have them factory installed. Mine don't appear to have these, but when installed the hose won't screw on. What am I doing wrong?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 02-15-2016, 07:24 PM   #2
jweb
jweb's Avatar
Re: MMll power rack question
Any pictures of the rack outlets? Which hose kit do you have?
When I switched to a power rack I got 2 metric to an fittings then made some hoses to fit. Like this
http://www.technafitstore.com/PSR-1416-p/psr-1416.htm
Not sure if those are the correct ones for your rack, but they seem to have good prices on fittings.
jweb is offline   Reply With Quote
Old 02-16-2016, 04:07 PM   #3
mobileortho
I ended up having to have buy another hose all together, the pressure port opening is 1/2, the hose they supplied was 7/16. On the return side I had to cut down the height of the brass fitting. Hoping there are no leaks.
Robert C.
1950 3600
Old 02-16-2016, 04:54 PM   #4
jweb
jweb's Avatar
I didn't have it right the first time either. The first hose I made blew apart about 1 minute into the first drive, right at the end of my driveway.
