Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-25-2016, 11:51 AM   #1
blazer2007
.023 vs. .025 welding wire
I have a little 110 wire feed welder with gas and lately I,m not having much luck finding 023 wire now,the smallest is 025.I,m almost running out..Do you think I will notice much,I,m doing patch repair on a quarter panel.
blazer2007 is offline   Reply With Quote
Old 02-25-2016, 02:05 PM   #2
daddyjeep
daddyjeep's Avatar
Re: .023 vs. .025 welding wire
Worst case you will have slightly more grinding to do since you are laying down slightly more material. I used .030" on my last body work project because I couldn't find .025.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-25-2016, 09:47 PM   #3
mongocanfly
mongocanfly's Avatar
I've been buying all my wire off ebay...I just looked and there's plenty of .023 on there to chose from.
Old 02-25-2016, 10:36 PM   #4
JJH Jimmy
JJH Jimmy's Avatar
.023, .024 & .025 wire, contact tips and drive wheels are all interchangeable with each other. Different manufacturers use different discription but essentially all the same.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 02-26-2016, 06:55 PM   #5
truckster
truckster's Avatar
I bought a 10 pound spool of .023 on Amazon just a couple of weeks ago.
truckster is online now   Reply With Quote
Old 02-26-2016, 10:51 PM   #6
franken
I think a thousandth or 2 isn't a big deal. Have you looked into what a thousandth is?
