Old 03-02-2016, 12:47 PM   #1
Mrturner1
How many amp are the glass fuses in cab?
Wiring my 70 c10 back up, and I can't quite read the fuse panel to see how many amps the fuses I need are. So far I need the PNL Lights, Cluster Feed, and the one top left of the whole panel
Mrturner1 is offline   Reply With Quote
Old 03-02-2016, 01:04 PM   #2
70cst
70cst's Avatar
Re: How many amp are the glass fuses in cab?
Maybe this will help
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-02-2016, 01:06 PM   #3
70cst
70cst's Avatar
More info
Fuse Requirements
Table 11-1 Fuse Requirements
28
Cigarette Lighter………………………………………………… 20
Headlight Switch………………………………………………… 30
Emergency Flashers……………………………………………. 15
Turn Signals………………………………………………………. 15
Gauges……………………………………………………………… 10
AC/Heat Relay…………………………………………………… 5
Radio (Constant)………………………………………………… 10
Horn………………………………………………………………….. 20
Door Lock………………………………………………………….. 20
Wipers………………………………………………………………. 15
Brake Switch……………………………………………………… 20
Dome/Trunk………………………………………………………. 10
Electric Fan Relay………………………………………………… 5
Power Antenna…………………………………………………… 10
Power Windows………………………………………………….. 20
Electric Fuel Pump………………………………………………. 15
Coil……………………………………………………………………. 30
Radio Ignition (Switched)…………………………………….. 10
Backup/Cruise Control…………………………………………. 10
Old 03-02-2016, 01:09 PM   #4
Gromit
Found this - it is a little different than above but looks like the one in my 70
Gromit is offline   Reply With Quote
Old 03-02-2016, 07:22 PM   #5
SS Tim
SS Tim's Avatar
From the 70 Factory service manual which you should have and use. Its even in the driver's handbook.
SS Tim is offline   Reply With Quote
