BlahBlahBlah
Bolt in C notch template?
Ive been putzing around with my panel chassis and was going to put my CPP C notches in and couldn't find the template. Did they even come with one, or was it just a fit the best you can deal?
If it does have a template does anyone have one in a PDF or something they could email or mail me. Id cover any postage costs. Thanks, Mark
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Bolt in C notch template?
I would just make a template off of your notch.
That's what I always do. I use thick poster board or thin gasket material.
That method worked for me too
Posted via Mobile Device |
Same here.
Bottomed the rear axle against the frame & marked the axle centerline on the frame. I made a posterboard template of the notch area using the CPP notch as the guide. I put the center of the template @ the centerline marked on the frame & scribed the area to be cut. I drilled holes @ the corners & cut from the bottom of the frame rail up to the drilled holes & then cut the area between the drilled holes. Smooth everything so there are no sharp edges!
Moderator
![]() Join Date: May 2007
i installed my cpp notches exactly as scoti described above. it went very smooth, and i have some pics on my build thread.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
BlahBlahBlah
Hey thanks guys, I really appreciate the answers. Looks like it was right there in front of my nose the whole time.
I still recommend using the method described to center the axle. If I would have followed the published directions included w/mine, I would have been off center @ ride height.
BlahBlahBlah
This isn't going to be a bagged ride. Its a panel so its pretty heavy in the back, and will have a 6 inch drop in the rear. Figured the C notch would be good insurance from bottoming.
I am about to just start my C notch, I have a 69 c10. I have the bed off and was about to start removing rivets. It looks to me like i will have to move the panhard bar mount on the frame as the c notch (cpp) hits it when lined up wit the center of my axel. anyone else have this issue?? seems like there is about 1/2" interference.
69 c10 lwb |
I've installed the CPP notch & there wasn't any clearance issues @ the Panhard bar.
I am a Referee of life.
Try looking at the March issue of Custom Classic trucks.They did a write up on this in it.With pitchures an everthin.I just read it today and when I saw your question I could not help being a smart alec.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
BlahBlahBlah
Hey thanks for this! Probably up to June on the stands by now lol.
Thanks, I had a look at the issue. I think my panhard mount is different than the one in the photo's. Mine has 2 rivets on either side and one farther up on the frame. The one in the photo's has the rivets inside the walls of the mount. I'll post pics today with what i mean.
69 c10 lwb |
The first two are pictures I have found in installation instructions (pic 1 board member pic 2 from cpp), the last 3 are pictures of my mount and location.
69 c10 lwb |
#15 |
BlahBlahBlah
Thanks for the pics. Does anyone ever run a weld bead around them (leaving the bolts in), or does that mess with the way the bolts hold them in?
#16 |
My panhard mount is the same (68 C-20) and I plan to trim the notch around the panhard mount. How'd you end up installing yours?
1968 LWB C20 / AC / Wood Bed |
