Old 02-22-2016, 07:31 PM   #1
tsutomu27
Bolt on EFI kits....opinions?
hey guys,
just curious what peoples' opinions are on the EFI kits? the ultimate preference (for me anyway) would be a full on LS swap. but i can't make it work financially nor logistically right now (the blazer is about to be my daily).
although i want any and all opinions, i'd be really happy to hear from someone who's actually used one.
what kind of improvements did you see? (just ease of starting? throttle response? mpg?)
thanks guys!
**also, the ones i've "looked up" are: MSD , FAST EZ-EFI 2.0, Edelbrock E-Street, and Holley
Alan
1965 Chevy Suburban. LT1, 4L60e, bagged
tsutomu27 is offline   Reply With Quote
Old 02-22-2016, 08:14 PM   #2
audaciousduo
Re: Bolt on EFI kits....opinions?
I'm running a TBI kit from http://www.affordable-fuel-injection...mplete-system/ I put in on a new crate engine from GM and have been very happy with it. Starts every time, was plug and play and has been issueless on the steepest of inclines. For 4-500 more than a holley off road carb it comes with the computer, new distributor and great instructions. I'd do it again.
audaciousduo is offline   Reply With Quote
Old 02-22-2016, 08:17 PM   #3
tsutomu27
thanks, Audaciousduo! and you didn't do anything to the fuel system, outside of that external pump that's in the kit?
what's your mpg like?
Alan
Old 02-22-2016, 08:35 PM   #4
audaciousduo
I haven't figured it out but it's reasonable. Much better than the 4 Bbl was. My issue is the C%$P 3.07's I'm running with 33" tires. I have a set of 4.11 axles I'm swapping which will give me a better idea. I did have to but a cheap plate to block off where the manual pup goes into the block and plumb in a return line to the tank but fairly straight forward.
Dave
Old 02-22-2016, 10:32 PM   #5
tjsblazer
tjsblazer's Avatar
see this link. A fairly new system that for the most part seems to be getting favorable reviews online.
http://67-72chevytrucks.com/vboard/s...d.php?t=686601
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 02-23-2016, 12:37 AM   #6
tsutomu27
Jeff - i looked at that link...and then continued to read several others about that system. it really looks like a legit solution. all the reviews i read (however, it was more of a skimming of them) seemed really positive.
appreciate the head's up...i'll be investigating further!
Alan
Old 03-08-2016, 08:47 AM   #7
EricSean
Active Member
This is a system I am thinking about going with. Looks like a good system and can run plenty of HP. http://fitechefi.com/
EricSean is offline   Reply With Quote
Old 03-08-2016, 10:04 AM   #8
hemi43
hemi43's Avatar
If it was me, I would go with something from Holley. The main reason is parts availability down the road. I used a Commander 950 for my street rod (10 years ago now) and was very happy with it and put over 25000 miles on it. Years later I was still able to get replacement parts easily. What ever you decide to go with, make sure you get a system that controls fuel AND timing. Some kits being sold at a reasonable price don't do timing, and IMO that's just a waste of time. I will never go to a carburetor again.
Another bit of advice is go with an in-tank pump, preferably with a return line. Your fuel will stay cooler and you'll barely hear the pump run.
Dan
hemi43 is offline   Reply With Quote
Old 03-08-2016, 10:08 AM   #9
tsutomu27
those are great points, Dan. appreciate the input!!
**i hadn't considered the lack of timing control, actually...
Alan
