Old 03-06-2016, 01:22 PM   #1
RP_Gregg
I need help with a pulley
Hi guys I'm brand new to this forum and this is my first post but I'm trying to find a water pump pulley that someone would be willing to sell if possible because non of the aftermarket pulleys fit right it came off a 68 c10 with factory ac and factory p/s any help would be great thanks
RP_Gregg is offline   Reply With Quote
Old 03-06-2016, 01:29 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: I need help with a pulley
First welcome to the board.
That is a crank pulley sir that you have posted not the water pump.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-06-2016, 01:33 PM   #3
RP_Gregg
Thanks but No it is deffently the water pump pulley it has an h.d cooling system it's just a rare pulley
Old 03-06-2016, 01:40 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: I need help with a pulley
I've been messing with these trucks for over 30 years and never seen that pulley for a water pump.
Can you get a picture of the back side of it. The part that hooks to the water pump?
This is a typical water pump pulley for a small block with AC,power steering.
Old 03-06-2016, 01:51 PM   #5
RP_Gregg
No problem here is a couple more pictures it's been pretty confusing for a lot of people but I actually found a thread on here about them if you would like I can find it again
Old 03-06-2016, 02:00 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: I need help with a pulley
That pulley cracked off in the picture? That's a first to! Man you got you something there to find. I have never seen anything like it. What size motor you talkin' about?
Is this it. I just did a quick search.
As stated, first time I've seen it.
http://67-72chevytrucks.com/vboard/s...d.php?t=689272
Old 03-06-2016, 02:09 PM   #7
RP_Gregg
Yea man the whole back side broke when the water pump decided to blow up on me. But here is the link I found it kinda towards the bottom but yea it's been a challenge finding one
http://67-72chevytrucks.com/vboard/s....php?p=5179116
Old 03-06-2016, 02:10 PM   #8
RP_Gregg
Oh and it's off a 327
Old 03-06-2016, 02:19 PM   #9
Andy4639
Old member
Andy4639's Avatar
Exclamation Re: I need help with a pulley
I'd get in the 66 truck area and start asking to. They seem to be on the 6 cylinders also. May want to ask local junkyards. Can you get a part number off of it? Heck who knows you may even beable to order it from a good parts guy at the dealership.
Old 03-06-2016, 09:59 PM   #10
toolboxchev
I am still having a hard time with that being a water pump pulley, yet so if you say so. I would post an ad in the wanted to buy section.
Lots of these parts crossed over to the car line up, maybe a Nova, or Corvette, even Caprice Classic with the same motor in some other catalouges out there.
Good luck in your quest, I realize you probably are in real need of the exact same thing.
toolboxchev is offline   Reply With Quote
Old 03-07-2016, 09:56 PM   #11
junkcarguy
That's the pulley that can with the dealer ac install kit under dash unit normally I have one at the house new in the box a long with the rest of the brackets to mount a ac compressor problem being im out of the country I could possibly get my wife to dig it out
junkcarguy is offline   Reply With Quote
Old 03-07-2016, 10:33 PM   #12
mike16
i have similar pulley on my crankshaft. it is part of an aftermarket ac installed on my 68 k20 back in the late 60 or early 70's. no way it would go on the pump. probably explains why it blew and tore apart.
mike16 is offline   Reply With Quote
Old 03-07-2016, 10:41 PM   #13
junkcarguy
Depends on the ac install kit the kit I have is nos I was the first to open it both water pump and crank are cast like that my kit was labeled 64-67 Chevy ii nova came from the back room of a machine shop that's been around for ever friend that works there said you have a nove here take this you may need it
