Old 01-18-2016, 11:48 AM   #1
rgunlock
rgunlock's Avatar
What is this pedal assembly piece?
A few years ago when I was doing disassembly, I tagged this as "fell out of pedal assembly". I don't have any pictures that show where it originally was. This is from my 78 GMC, manual transmission truck.
Anyone know where it goes, or have a good picture of it in place?
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-18-2016, 12:24 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: What is this pedal assembly piece?
looks like the brake light switch activator that allows the switch to operate
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-18-2016, 08:21 PM   #3
durty harry
durty harry's Avatar
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 01-19-2016, 03:10 PM   #4
rgunlock
rgunlock's Avatar
Thanks Bob. That makes sense. Now I just need to figure out where it mounts in the assembly.
Rick
Old 01-19-2016, 07:20 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Should be first bolt hole up from the pedal.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-19-2016, 09:22 PM   #6
73kay
Actually I'm almost positive there are two of those that link the dash and the brake assembly together. The small hole is for a dash bolt and the large hole is for the steering column bolts to go through. They are sandwiched between the brake housing and the steering column support. I'll try to find some pix. I could be wrong but I'm almost positive for once lol
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
Old 03-20-2016, 02:51 PM   #7
rgunlock
rgunlock's Avatar
Hi, I've started wiring under my dash and still need to figure this one out. I don't believe that the bracket I showed earlier was for the brake light switch. I had another misc. bracket and assuming I got this right, I think that switch is covered. I'm assuming that when the plunger part of the switch is allowed to extend, it closes the circuit so the brake lights come on.
Rick
Old 03-20-2016, 02:58 PM   #8
rgunlock
rgunlock's Avatar
So I also had this other switch which after researching I believe is a safety switch to prevent starting the truck unless the clutch is pressed. Mine was missing the "plunger" part, but after a lot of searching I found a new one that looks like a match. But I've searched for hours and haven't found a picture showing where/how it mounts. It was just hanging from the wiring when I disassembled my truck. So I've still got the original random bracket and now a switch to figure out. That small hole in the bracket is maybe 1/8" so looks more like for a spring than a bolt or screw. The large hole in the bracket is roughly the same size as the hole in the switch. I'm not even sure that they go together.
Any further help appreciated. 73Kay - did you ever find any pictures?
Rick
Old 03-20-2016, 03:51 PM   #9
rgunlock
rgunlock's Avatar
Never mind the pictures 73kay. I found the mate of this bracket where you said it would be - thanks much! Had to drop the column again, and loosen the brake booster but it slipped right in there. Now just got to figure out this switch!
Rick
Old 03-20-2016, 05:56 PM   #10
rgunlock
rgunlock's Avatar
Think I've figured out where the neutral safety switch goes. I'd bought what appears to be a copy of a copy of an 82 Factory Assembly Manual. The pictures are pretty good, but you can't read much of the text. Double-sided, the manual is about 5 inches thick. I did find a diagram after going through about 2/3 of it. The little 'j' bracket on the plunger does not hook to something - it snaps into a hole on the clutch pedal. Then the switch mounts in the square hole presumably (above and to the right in the picture). Looks like it needs a special plastic bolt #14013142. Found one online, but it says its for applications from 1979-84. Hope it works. For $10.00 I went ahead and bought it.
Rick
