Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-02-2016, 02:16 PM   #1
UATahoe
87 Silverado gauges, cluster, circuit card, and like new Tach/fuel combo
Doing an ls swap and going with Dakota digital gauges. No need for my originals. All gauges worked perfect, and the Tach/fuel combo is almost brand new. Bought it from the guys who was making them for Gm sports salvage. Can't remember his name but a lot of people on these boards have used this gauge. Gauge cluster was modified to fit the Tach. Bottom warning lights housings have to be removed from where the big fuel gauge was. Cluster is really nice I painted it white which really helped with the light output. The far left tab is still there but the bottom piece cracked off. Will post pictures. Looking to get $250 for everything.
UATahoe is offline   Reply With Quote
Old 04-02-2016, 02:45 PM   #2
UATahoe
Re: 87 Silverado gauges, cluster, circuit card, and like new Tach/fuel combo
Here is a picture of the tach/fuel gauge combo
Old 04-02-2016, 02:46 PM   #3
UATahoe
And here is a picture of the gauge cluster
Old 04-02-2016, 04:55 PM   #4
345HP87SSAC
pm sent. Do you have the wiring also?
345HP87SSAC is offline   Reply With Quote
Old 04-02-2016, 05:08 PM   #5
UATahoe
Didn't receive a pm. What wiring are you talking about? The tach takes a feed from the ignition coil. I can cut off the connector for the clock. Everything else is runs through the stock harness.
Old 04-02-2016, 05:23 PM   #6
345HP87SSAC
I thought the tach wiring and a few plugs in it maybe a resistor.
Old 04-02-2016, 05:44 PM   #7
UATahoe
No resistor. It was just a single wire run to the tach feed off of the ignition coil.
Old 04-02-2016, 08:06 PM   #8
TKCR
TKCR's Avatar
Are you willing to separate? Just interested in the clock.
Old 04-02-2016, 08:19 PM   #9
UATahoe
Want to keep it all together for now. Wouldn't even know how much it would be worth honestly.
Old 04-02-2016, 08:49 PM   #10
Tiger Joe
Does this work on tbi trucks or only carbs? Thought I had heard no tachs for tbi?
If it fits tbi I'll take it
Tiger Joe is offline   Reply With Quote
Old 04-02-2016, 08:55 PM   #11
345HP87SSAC
DO you currently have a mechanical speedo? If yes then this should work for you. If yours requires an electric speedo, then that part will not be right for your application.
I did the research on this topic, as I have TBI on my 89, and I was considering this unit. I have not made binding arrangements with the OP so good luck as it is a nice piece.
Old 04-02-2016, 08:57 PM   #12
UATahoe
Yep, works great for a tbi. My 87 is a tbi truck. Worked flawlessly. The speedo gauge is a mechanical gauge.
Old 04-02-2016, 08:58 PM   #13
UATahoe
The tach hookup was super easy. One wire connection to the ignition coil.
Old 04-02-2016, 09:10 PM   #14
Tiger Joe
Yes I have a mechanical speedo. Just went down a confirmed I have a cable(truck is up on my lift)
Sounds like it will work so like I sai I'll take it
Old 04-02-2016, 09:44 PM   #15
UATahoe
Payment received. Everything has been sold.
