Old 01-10-2016, 01:20 PM   #1
dman1982
dman1982's Avatar
electric fan question
maybe a dumb question but I'm running dual fans on my 5.3 k10, the one fan stays on as soon as i turn the truck on, the other one will come on once the motor gets up to 200 degrees or so (which has only happened a couple times) my truck will not get much above 150 degrees, how can i fix this and has anyone else ran into this issue? it throws a code for poor performance or something like that
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 01-10-2016, 01:30 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: electric fan question
You have to set the fans up in the tune. Mine did the same thing until I had the fans re-programed in the tune. I think normally the PCM/ECM/VCMs are programed for 1 fan so the second fan gets power all the time.
The LS engines are designed to run hotter for efficiency. My fan1 kicks on at 200º and fan 2 at 215º. Fan 2 never runs.
LockDoc
Leon
Old 01-10-2016, 01:31 PM   #3
dman1982
dman1982's Avatar
LockDoc
i see...well crap...thanks tho
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-10-2016, 01:35 PM   #4
LockDoc
LockDoc's Avatar
I added to my above post....
LockDoc
Leon
Old 01-10-2016, 01:38 PM   #5
dman1982
dman1982's Avatar
LockDoc
thanks man, i appreciate it....guess ill have to get another tune done...
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-10-2016, 02:46 PM   #6
ls1nova71
ls1nova71's Avatar
Has it always done this? How is it wired? Could be a wiring issue, if the fan comes on as soon as the key is turned on, try unplugging the PCM connectors and then turn the ignition on, if it comes on then it's not being commanded by the tune/PCM, if it doesn't come on, then you need to see what your fan settings are set at.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-12-2016, 02:52 PM   #7
dman1982
dman1982's Avatar
its always done this LS1nova, i unhooked the pcm and turned the key forward and no fan...so I'm guessing i need to retune?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 02-08-2016, 02:26 AM   #8
'68 Newtricks
'68 Newtricks's Avatar
(sorry, didn't modify my own harness) I've got both fans wired to my "low" temp ground signal from the harness. I also had a "high" temp wire but choose not to use it. To me, if you have dual fans, they should really both come on at the same time. If one is on, it will simply pull air from the least restrictive location..... the other fan opening, not from the other side of the fins. I also have an override switch to turn them on when my AC is on, so airflow is going across the condenser.
Check the wiring and tune I guess but think about just running off one ground signal.
edit: open fan hole comment is for those running shrouds, not fans directly mounted to radiator
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-08-2016, 03:30 AM   #9
ls1nova71
ls1nova71's Avatar
When wired like the factory does it, they both come on at low speed and high speed. On low they are run in series and high they are run in parallel so you're never pulling from just one side of the radiator.
Old 02-08-2016, 08:25 AM   #10
homemade87
This is correct, Both fans run 1/2 speed at the same time on low . The gm system requires a three relay system for it to work . If you only have 2 relays it will not do this . Also if your fan comes on at ignition on only ( no start up ) its either you have it wired improper or the pcm has a problem .
homemade87 is offline   Reply With Quote
Old 03-27-2016, 08:10 AM   #11
elf w/capital T
The three relay going to a vintage air trinary switch, anyone have a diagram i could follow for my build?
elf w/capital T is offline   Reply With Quote
