Old 03-16-2016, 09:12 PM   #1
68Stepbed
68Stepbed's Avatar
pinion angles for traction
OK, I seem to have a serious issue with traction(actually the lack of it) on my 68. It's lowered 4.5/6.75 and I've never adjusted the pinion angle. Would the correct angle help with traction? if so, what angle do I need to shoot for?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-17-2016, 07:05 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: pinion angles for traction
This might be a controversial statement - but - pinion angle has nothing to do with traction.
Removing tires from the equation, the traction comes from the forces through the suspension attaching points: the relationship between the "instant center" of the suspension and the center of gravity of the vehicle.
The instant center is determined by suspension type (leaf springs react through the forward spring eye; four link reacts to an imaginary point created by extending the control arms forward).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-17-2016, 08:22 AM   #3
68Stepbed
68Stepbed's Avatar
OK. That's the reason I asked in the suspension section. What should the pinion angle be compared to the driveline angle?
Matt
Old 03-17-2016, 11:33 AM   #4
Keith Seymore
For a control arm rear suspension: 1 deg to 3 deg u joint working angle
For leaf spring: 3 deg to 6 deg u joint working angle.
K
1979-1986
1986 - 2019
Old 03-17-2016, 01:25 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
My truck is lowered 7.5" in the back (6" spring, 1.5" block) and I used a 6* shim to get mine right. It is 4.5* coming off the trans yoke.
FWIW, I'm also using a PB Fab trans x-member, and the trailing arms are in the 2nd hole from the top. There are 4 adjustment holes on it.
I also had traction problems with my truck, but since I windowed the #1 cylinder, it doesn't spin the tires much at all
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-17-2016, 02:28 PM   #6
PGSigns
PGSigns's Avatar
Pinion angle will not affect traction at all. Suspension geometry, weight split, shocks and tires is where you will find added traction.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-17-2016, 03:42 PM   #7
68Stepbed
68Stepbed's Avatar
Is there a way to optimize the stock trailing arm suspension to gain better geometry, or am I simply just looking at buying parts made for that?
Matt
Old 03-17-2016, 04:53 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
I'm pretty sure I've seen replacement front mounts that will allow you to alter the mounting point of the trailing arms to change anti-squat. I'm using the PB x-member with adjustable mounts. The Hotchkis kit comes with the brackets I'm talking about, but you could probably make some for WAY cheaper.
I really think it's more about weight distribution and spring/shock stiffness than anything. I found that even with the fuel tank and battery mounted behind the rear axle on my truck and 345mm wide (13.5+ inches) rear tires that I could obliterate them in 1st-3rd if I was giving it full throttle, no matter how fast I was going. The truck was really planted around turns and stayed planted as long as I didn't jab at the throttle. Power slides were EASY anytime. I tried softening my shocks (Chassisworks DA) to improve straight line traction, and that didn't help much. I have Hotchkis rear springs, and they might be a bit stiff, which doesn't help at all either.
Adam
Old 03-17-2016, 06:30 PM   #9
69gmcc10
69gmcc10's Avatar
Changing the instant center and anti-squat of the truck to increase traction on these trailing arm trucks is actually kind of simple. It takes a little work but is simple, it will also help correct some of the pinion angle issues caused by lowering springs.
With every inch you lower the rear with a spring it points the pinion downward more and more. There is "some" power loss with improper pinion angle, but even more concerning is u-joint life, because every degree you get further from the ideal operation angle, fatigue and failure of the joint goes up exponentially, literally. To counter this partially and to raise the Instant Center and anti-squat of the now modified truck suspension you need to raise the front mounting point of the Trailing arms. This will have a positive effect on both traction and u-joint life.
To raise the mounting point of the trailing arms on the crossmember you have some options, there are a few different companies that make trailing arm brackets with adjustment holes on them or you can simply flip the existing mount which will net about 4" of lift for the price of 16 grade 8 bolts. to flip the mounts the arms mount to you simply unbolt the arms from the mounts on the crossmember, drill out the rivets that hold the brackets to the crossmember, flip the mount upside down and bolt it back onto the crossmember with 4 bolts in the holes that are not obscured. Then mark, drill, and bolt the other holes so the mount is real secure. Reinstall trailing arm in the hole and take it for a drive.
When you do this it moves the Instant Center up and relaxes the angle on the u-joints at the same time. I did this just to increase traction because I didn't lower my truck, I think it is in my build thread if you want to look, but now my trucks hooks up and hustles! big improvement!
This post from the Make it Handle thread explains what we are discussing here about Instant Center and Anti-Squat even better and it has an illustration. http://67-72chevytrucks.com/vboard/s...postcount=1032
Do a search for flipping trailing arm mounts for more info. This is all about physics and geometry, after getting the chassis close enough for your liking to correct the issue you can then fine tune with springs, shocks and tires.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 03-18-2016, 01:24 AM   #10
Robznob11
Robznob11's Avatar
Talking Re: pinion angles for traction
These guys are absolutely shooting you straight. On the cheap flip your oe mounts. Ece will sell you a set of there brackets if you call and ask. You can get the angled ones or the flat ones that would work on a homemade or aftermarket type x member. The best option if you ar going to stick with the oe member is to get a hotchkis anti squat kit. It is the brackets your looking for adjustable in one inch incredimunts. As far as pinion angle you need to make sure that is correct too. You need the rear @ 1.5* down as compared to the front angle. Example if your tranny is 3* down your rear should be 1.5* up. Some will tell you that it's not as important on our trucks if you have trailing arms because they don't wrap up like leaf springs. Either way your pinion still tries to climb the ring gear under power trying to make your pinion come up and I feel it still has some movement. Either way anything under 2* operating range is a safe place. Never have it straight in line tho. Also many argue over checking angles with ride hight or frame level. I still agree with the ride hight ground level method. Who really cares how it's positioned in the frame as long as the operating range of the joints are correct. All manufactures placed rear motor pinion angles at -3* ish. Hence the reason sbc manifolds are angled where the carb sets. This is for leg room etc. Chassies builders for race cars actually prefer a positive rear engine angle....this is lengthy and very arguable so I plan to say no more on this page but do the research and form your own opinion because 20 people will give you 20 answers of why they are right! Good luck bro!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-18-2016, 08:29 AM   #11
68Stepbed
68Stepbed's Avatar
Thanks for all the advice, guys. I've looked into the anti-squat brackets, but some seem a bit pricey. I'll look into flipping the OE mounts for now, but eventually, I'd like to run a PB tubular crossmember and some aftermarket trailing arms with adjustable end links, or I may just look into the 3-link setup from NoLimit.
Matt
Old 04-04-2016, 03:55 PM   #12
68Stepbed
68Stepbed's Avatar
OK, I'm strongly considering flipping the trailing arm mounts. When I do, I know it'll change my pinion angle. Does anyone that's done this know what degree shims I'll need to get the correct angle, or am I going to have to figure it out afterward?
Matt
Old 04-04-2016, 03:57 PM   #13
Robznob11
Robznob11's Avatar
Measure after, got mine at Calvin's racing
LED TAILS
Old 04-04-2016, 04:04 PM   #14
Robznob11
Robznob11's Avatar
I ment to say Carl's racing. They are billet not cast.
LED TAILS
Old 04-04-2016, 04:52 PM   #15
69gmcc10
69gmcc10's Avatar
Excellent to hear you are going to do this! do you have a 1 piece driveshaft or a 2 piece? How is your truck lowered? Is it a 5" spring with 1.5" block? is it a 6" spring with some shims under the axle? is it on air? what panhard bar do you have (I'm curios, its has little to do with what we are talking about)?
The more info you get us the better we can help, but a simple rule of thumb on a 1 piece drive shaft is that you want the pinion angle to match the trans output shaft and on a 2 piece shaft you want the angle to be same as the first drive shaft. since every truck is a little different it would be wise to flip the mount get it on the ground, measure your angles, and order accordingly so you have the correct shim and not a guess.
Old 04-05-2016, 08:48 AM   #16
68Stepbed
68Stepbed's Avatar
It's a 6" spring with 3/4" lowering blocks. 1 piece driveshaft. ECE super track bar.
Matt
Old 04-05-2016, 08:53 AM   #17
68Stepbed
68Stepbed's Avatar
Do you have a part number or a link? I can find angle shims, only lowering blocks.
Matt
