Hi New Member
Hi all. Been visiting this site for awhile now. Finally able to post something since I found a truck.
71 c10 long bed(yes I wanted a long bed). I will post up pics when I get some new ones, as the only ones I have include the PO's house so I don't want to put his stuff on the web. Has the usual problem with rust, but we will see. Need to do work on the door panels, dash and seat, so I will be asking a lot of question. First question is it need new outside door handles. Will these work? https://www.classicparts.com/1967-72...ctinfo/18-113/ THX Tim |
![]() Join Date: Aug 2004
Re: Hi New Member
Welcome!
If the door handle push button has fallen in, there is a fix for it. Might save you a couple of bux. Worth a search.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Re: Hi New Member
Here's SPID
![]() Join Date: Apr 2016
Re: Hi New Member
Welcome aboard! We look forward to pictures and questions. Those do look like the correct door handles.
Re: Hi New Member
greeting(s) to the board ...
dont want to hear excuses, i want to hear solution(s) |
Re: Hi New Member
Is there any way to tell what the original transmission the truck came with from the spid?
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Hi New Member
Welcome to the boards and you have chosen to be part of the best website on the Internet.. Seeing there is nothing called out on the spid it would have come with a 3 speed manual column shift affectionately known as 3OTT for 3 On The Tree..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
