72 Suspension
What is done to the front end and rear to get that "look" everyone has...
I have a 72 c10 with front disks brakes and rear coils. stock rear lower front?? Any help would be great. I'm prolly gonna rebuild the complete front suspension and brake components anyway so I would like to do "once and done". I don't wanna slam it to the ground just maybe a touch lower??? Thanks, sorry for all the dumb questions |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 72 Suspension
Welcome to the boards and no question is dumb. Even folks that have been on this site for 15 years still ask questions when they run into something they are not sure about. There are a multitude of things you can do to lower your truck. First you have to figure out how low you want to go then depending on your preferences and budget decide from there. If you use the search button on the top right of this page you will find multiple posts on the different ways to lower your truck. If I was you I'd take some time to study the various options for lowering.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: 72 Suspension
I searched the forum earlier today...Do I need spindles since I already have front disks??
2" front 4" rear sounds like what most do to keep a nice ride. I'm planning on tearing into this soon and wanna have parts on the shelf to do it up....Any ideas on what brand?? I don't want cheap junk but don't need top shelf either.. |
Re: 72 Suspension
I like the ECE 4/6 kit....part #902-6572-46kit.
This a good kit??? |
Re: 72 Suspension
I'd guess you are talking about a 4/6 drop (4" drop in front, 6" in the back). From the factory, the rear is higher than the front, so the extra 2" drop levels things out.
Post a pic of one that has the look you want. Or, as mentioned, do a search. There are tons of pics/examples on the site with drop specs, wheel size, tire size, etc listed. This link has some examples. I know there are others. http://earlyclassic.com/Tech.aspx?ca...=Stance+Photos |
#6 | |
Re: 72 Suspension
Another thing to really enhance the handling of your truck is if you do not have one on your truck already is the addition of a front sway bar. http://www.earlyclassic.com/home.aspx http://www.classicperform.com
Re: 72 Suspension
Take a look at the pictures I have posted on my '72 I have the CCP drop springs front and rear, 3" front and 5" rear using all other factory parts. Once you get into the 4/6 drop area you should be looking into shock relocation brackets, adjustable panhard bar, and to a lesser extent C-notching the frame. for me the 3/5 was the perfect daily driver drop, but to each thier own.
1972 C10 - It might be old, but it's not slow |
#8 | |
Re: 72 Suspension
Re: 72 Suspension
Here is a quick shot for reference.
My Rims/tires are 255/35/18 front and 285/35/18 rear CPP 3" drop springs front and 5" drop springs rear. ![]()
