Old 04-13-2016, 03:15 PM   #1
jamie72
jamie72's Avatar
inline fuel pump
in the process of getting a 02 5.3, already have a new blazer tank so what inline fuel pump should i get?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-13-2016, 03:54 PM   #2
mongocanfly
mongocanfly's Avatar
Re: inline fuel pump
I used a walbro 255 inline on my 6.0..no issues so far. If your using a new blazer tank why not use a in tank pump?
mongocanfly is online now   Reply With Quote
Old 04-13-2016, 04:44 PM   #3
zach_carver
zach_carver's Avatar
I also used walbro with my LS2 and vette filter/reg combo. So far so good. Once I relocate fuel tank to under bed Ill install in tank pump though. Kill the noise and help pump last longer..
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 04-13-2016, 04:44 PM   #4
jamie72
jamie72's Avatar
really its easier to plumb it inline, than to cut up and weld in a flange for the in tank pump,unless there is an easier way..
jamie72
member #807
www.antlertalk.com
Old 04-13-2016, 05:45 PM   #5
mongocanfly
Inline pump, vette filter reg is def easier but if I had a new tank to start out with I would have went in tank just to clean it up install and keep the pump cool..noise isnt much of a problem on mine...remember you'll need 3 barb sending unit on your tank..one for suction ..one for return..and one for tank vent.
Old 04-13-2016, 06:51 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Inline pumps are plenty fine for most of what we see folks building on here. The 255's will fuel LS motors up to around 500hp, depending on a few factors.
You get to a certain point when the smaller single pumps won't cut it, you can run twin pumps or one of the "upmarket" inline options. The intank will always have an advantage in terms of supply and cooling, yet when you get REAL big, many of the fuel systems are inline (or high pressure compound fuel systems). The curve kinda goes like this:
small inline->(small in tank)->twin inline->(twin intank)->Large intank*uncommon*->Large Inline->Race /Compound Inline->HP Mechanical
I don't know why I bothered typing that last part but I did so now you just read it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-14-2016, 07:38 PM   #7
jamie72
jamie72's Avatar
thanks guys, i`m just wanting a dependable system one of the reasons i was thinking inline is in case i ever needed to change it.
jamie72
member #807
www.antlertalk.com
Old 04-14-2016, 09:23 PM   #8
mongocanfly
I've got about 7-8000 miles on my walbro 255 vette filter reg setup...no issues so far, very reliable and seems to be the go to setup for most people
