Old 04-16-2016, 07:25 PM   #1
c10 custom
sound deadener ?
Hello everybody i am going to install new carpet but i want to install some sound deadener but what kind should i go with ? i was thinking DYNOMAT
but looking for opinions thanks everybody
c10 custom is offline   Reply With Quote
Old 04-16-2016, 09:14 PM   #2
flashed
Re: sound deadener ?
I used the cheap stuff from Lowes ,Peel'N'Seal ,worked great .
flashed is offline   Reply With Quote
Old 04-16-2016, 09:38 PM   #3
MidLifer
MidLifer's Avatar
I always tell people to read this guy's site before spending a lot of money lining their entire cab in Dynamat or another product. Those products are not truly sound deadeners, they are vibration dampeners, and to get the effect you only need to cover 25% of the sheet metal. To truly deaden sound you then need to lay down a layer of foam and put mass-loaded vinyl (MLV) above it. The MLV is what deadens the sound. MLV is heavy and dense, which is what keeps sound from passing through it.
This is well worth the read:
https://www.sounddeadenershowdown.com/
MidLifer is offline   Reply With Quote
Old 04-17-2016, 12:47 AM   #4
Z10
Z10's Avatar
That's exactly what I did. You can see it on my build thread below.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
