Old 02-06-2016, 09:11 PM   #1
lyrikz
PITbut
lyrikz's Avatar
This can't be right. Transfer case linkage.
Having my tcase rebuilt and I noticed the linkage when I removed it.
I added a pic and a quick video.
Video shows the play in the unit.
http://smg.photobucket.com/user/jcem...larur.mp4.html
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-06-2016, 09:25 PM   #2
68panelman
68panelman's Avatar
Re: This can't be right. Transfer case linkage.
That is an original linkage, but appears to have a bolt welded to it. Probably welded at the wrong angle giving it the excess slop.
68panelman is offline   Reply With Quote
Old 02-07-2016, 12:02 AM   #3
lyrikz
PITbut
lyrikz's Avatar
Ok. So if I got that bolt out of there and added a bushing kit I should be ok...
That things heavy.
and sold.
Old 02-07-2016, 02:10 AM   #4
bhc41051
bhc41051's Avatar
From the parts book.
bhc41051 is offline   Reply With Quote
Old 02-19-2016, 04:30 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Any idea where i can purchase that part. Pt# 11 in the lower diagram? Or what busing i can use on the shifter also since mines missing.
and sold.
Old 02-19-2016, 04:43 PM   #6
68panelman
68panelman's Avatar
I saw one on the parts board a few weeks ago, you can check both areas, pickups and blazers, any four wheel drive linkage with a 205 will do, I'll keep my eye out for you also and I look through my stash.
Old 02-19-2016, 04:47 PM   #7
68panelman
68panelman's Avatar
Here's a pic of the earlier style linkage for the 205
Old 02-19-2016, 04:58 PM   #8
68panelman
68panelman's Avatar
Here's what you're broken one used to look like.
Old 02-19-2016, 05:06 PM   #9
lyrikz
PITbut
lyrikz's Avatar
I looked for an aftermarket unit and found something like this, but i have no idea about this 4wd stuff. I need to do some more research. Why does this piece have two levers?
and sold.
Old 02-19-2016, 05:19 PM   #10
68panelman
68panelman's Avatar
That's a picture of an aftermarket twin shift. From the factory they came with a shift plate that tied both rods together, with the twin shift, they work independently. This means you can have two wheel drive with the low option, meaning the shift pins are operating independently also.
Old 02-19-2016, 05:22 PM   #11
lyrikz
PITbut
lyrikz's Avatar
OH, damn. Sounds like i could get myself into trouble with that. I would like to have a stock unit. Just need to keep looking around. Having a hard time using the search function or the right words.
and sold.
Old 02-19-2016, 05:27 PM   #12
68panelman
68panelman's Avatar
No problem man, that's what these forums are for, that's what it's all about.
Like I said, I'll keep my eyes out for you, and also on the parts board too.
Old 02-19-2016, 05:30 PM   #13
lyrikz
PITbut
lyrikz's Avatar
I appreciate it. Those twin sticks look pretty neat. Im watching videos on them now. I would NEVER need what they are capable of doing, but they look pretty cool.
and sold.
Old 02-19-2016, 05:31 PM   #14
68panelman
68panelman's Avatar
If it were me, I would attempt to bend some round stock, then grind on the end to fit into the linkage / levers
Old 02-19-2016, 05:33 PM   #15
lyrikz
PITbut
lyrikz's Avatar
That is what i was thinking.
The bolt that holds the shifter on the case appears to be a special bolt also.
and sold.
Old 02-19-2016, 05:38 PM   #16
68panelman
68panelman's Avatar
You mean this one? There's 2 different types of these also, one has the smaller thread, and one larger. straight shaft one is greasable. Now you're getting into different levers.
Old 02-19-2016, 05:40 PM   #17
68panelman
68panelman's Avatar
A picture would have helped
Old 02-19-2016, 05:51 PM   #18
lyrikz
PITbut
lyrikz's Avatar
Ya, that, i dont have that bolt either. ahahah..
you want to sell those two little parts. ??
and sold.
Old 02-19-2016, 05:53 PM   #19
68panelman
68panelman's Avatar
I wish I could, these parts belong to units that I need.
Old 02-19-2016, 06:01 PM   #20
lyrikz
PITbut
lyrikz's Avatar
You surrrreee???? I have cold hard cash...... How can you turn this down.
I have about this much.. LOL, thanks for your time though man.
and sold.
Old 02-19-2016, 09:44 PM   #21
franken
To use a twin stick, you'd need to mod the shift rods.
I have the little linkage bit on a spare shifter. Lots of writeups on how out there.
The pivot bolts may still be available from folks who sell NOS parts. I'd google np205 pivot bolt. Or measure the OD of the bolt that's there (looks like .5") and get a bushing the same length as the shifter is wide at that spot. You may need to cut the bushing in half lengthways to get it over the threads.
For the linkage, why not gently break the weld on the shifter, cut the bolt to the right length and drill a cotter pin hole. Maybe gring the hex head down or hack it off and start fresh.
Looks like the number for the greaseable bolt is 14009313. I see them available for ~$3. A few keywords and seconds to search.
Old 02-19-2016, 10:58 PM   #22
lyrikz
PITbut
lyrikz's Avatar
I didn't really know what it was called so I was having issues searching. Where are you finding them for $3.
Thanks for the info. I will probably be doing everything you said but I really like that twin shifter setup.
and sold.
Old 02-19-2016, 11:00 PM   #23
lyrikz
PITbut
lyrikz's Avatar
Got em thanks
and sold.
Old 02-19-2016, 11:50 PM   #24
57taskforce
All about them K’s
57taskforce's Avatar
One cool thing about the twin stick is that, with some shift rail mods it will give you front wheel drive only as well. There are times when off roading when that does come in handy believe it or not. My 3100 is going to get a twin stick setup someday.
Tyler
Old 05-13-2016, 10:50 AM   #25
dsworm08
where did you find that bolt? mine is gone and need to figure out what to do now! no gm dealers have 14009313 bolt..
dsworm08 is offline   Reply With Quote
