65 Chevy swap?'s
Ok guys I need to know what all would be needed to do an ls swap from a gen1 with a 700r4? I'm lookin at a 5.3 dropout with as complete as possible. I had a cam lobe go flat and am debating if it's worth risking trying to slide a cam and lifters in and go through break in or just say screw it and ls.... So I need to know personal experience on what you have spent on the simple swap
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
meowMEOWmeowMEOW
Re: 65 Chevy swap?'s
Tons of builds, the "what ya got" thread, some of the Faqs, and the advanced forum search tool (4k posts, i know you know where it is
![]() That stuff will probably answer 500x the info in way less time than we can in a couple posts. Glue your eyeballs to the screen for a bit and you should get everything you need and more. Stuff like your goals, budget, skill level, time, are all going to be factors. IMO, once you get through some of the info thats out there and fill in some of those blanks for the goals, budget etc, then we can actually give you some better advice. There are just so many options out there now that we're throwing darts blindly otherwise, and conflicting advice is worse than no advice at all.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Aug 2004
100% agree with Br3w!!!
A simple 4.8/4l60e will run you around $12-1500 alone and the there is mounts, fuel, exhaust, drive shaft.....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
That's what I was wanting to know minus all the nickel and dime stuff...
