Old 07-29-2014, 09:41 PM   #1
CParnell
CParnell's Avatar
68 GMC Project Tommy
25 years ago my grandparents gave me this truck. Even at a young age I loved fixing things and they must have figured this was a good outlet for it. She has some good war wounds, but she worked hard as a farm truck. Life got in the way and even though I always found time to go and visit my grandparents and the truck I didn't have the means to do anything with it. Well some time has past and I finally have the time/money to make this dream finally come true. This isn't going to be a fast build but I hope you will enjoy it. Plans are to keep the six if it isn't cracked and add a procharger and some other fun bits. For now enjoy the pictures.
That's me in the back of the truck with my brother in tow about the time I got the truck.
And on the trip home from the farm.
And the progress today. Also it is almost exactly 25 years to the day that I got the truck.
I'm keeping the end of the box for a shop seat like I have seen on here.
1968 GMC 910 Project Tommy
1974 Olds Cutlass
CParnell is offline   Reply With Quote
Old 07-29-2014, 10:42 PM   #2
Hardesty454
Hardesty454's Avatar
Re: 68 GMC Project Tommy
Good lookin truck. What are the main plans? Make sure to not bite off too much. Most get bored and quit that way. :/
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 07-31-2014, 08:37 PM   #3
CParnell
CParnell's Avatar
The current drivetrain plan is to run the 6 if it's not cracked. With that I would like to run a small Procharger for about 15 pounds of boost. There is also a couple aluminum heads I'm looking at along with EFI. I would then back that up with a Holinger SMG transmission.
If the 6 is actually broke then It will be an LS7 and T-56 combo.
Haven't decided on a colour yet. White or blue just dunno. Will lower it some and run 18's. I have a million other ideas but It depends on which engine is under the hood. I will be keeping it 68 GMC though and getting copies of the 910 badges from the original truck made.
1974 Olds Cutlass
Old 07-31-2014, 08:38 PM   #4
thelonerife
thelonerife's Avatar
Nice project!
thelonerife is offline   Reply With Quote
Old 07-31-2014, 08:41 PM   #5
CParnell
CParnell's Avatar
1974 Olds Cutlass
Old 07-31-2014, 10:15 PM   #6
Hardesty454
Nice plans! Hope you got the spare coin if that I-6 is busted. Ls7/t56 ain't cheap!!!
Rob
Old 08-01-2014, 09:35 AM   #7
BigDaddyV
BigDaddyV's Avatar
Nice truck and start, I would love to see the procharged 6 rollin! Rock on, I'll follow along
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 08-01-2014, 11:58 AM   #8
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Love seeing GMCs stay on the road. And that red is a bonus. I just sold that exact same colored 68 GMC to a friend. Good luck with the build as you have a great clean truck to start with for sure.
Mike
Cash3481 is offline   Reply With Quote
Old 08-04-2014, 09:33 PM   #9
CParnell
CParnell's Avatar
More progress today. The six is looking good so far no visible cracks or breaks. Found all my seat foam. Most was in the heater, but some unlucky bastard of a mouse made a nest in the clutch. It didn't end well for them.
And the assistant sleeping on the job.
1974 Olds Cutlass
Old 08-05-2014, 06:05 AM   #10
SuperC10Tex
SuperC10Tex's Avatar
Good start to a 4-eyed !!! Keep the pics coming.......
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 08-11-2014, 09:36 PM   #11
CParnell
CParnell's Avatar
Well I got the cab gutted today and pulled it off the frame. Not much left to take apart. What's the best way to remove the frame rivets?
1974 Olds Cutlass
Old 08-12-2014, 05:13 PM   #12
SuperC10Tex
Looking good, keep the pics coming!!!
Old 08-12-2014, 06:05 PM   #13
BigDaddyV
BigDaddyV's Avatar
Looking Good!
as far as the rivits, Cut an X in the top of it with a grinder and use a chisel to knock them loose, or you could try a hammer chisel if you have one handy.
Old 08-14-2014, 12:27 AM   #14
CParnell
CParnell's Avatar
So I stripped the engine down today. The amount of crap in the bottom of the pan was shocking. I had fun taking it apart, I have built a few engines before but no inline sixes. Dropped it off at my machinist to get cleaned, check for cracks and let me know how much needs to be cut to get the bores back in shape.
1974 Olds Cutlass
Old 08-14-2014, 12:54 AM   #15
Molberg
Molberg's Avatar
Nice start!... sub'd
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 08-14-2014, 06:58 AM   #16
BigDaddyV
BigDaddyV's Avatar
Please share what you learn, I've built every V8 I can think of but never a I6 either. Keep up the good work
Old 08-14-2014, 08:29 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
Looks like a nice project. That cab also looks to be pretty solid. subscribed.
Old 08-15-2014, 10:45 PM   #18
CParnell
CParnell's Avatar
Well 6 days all on my own and the major disassembly work is done. Next stop is shortening the frame.
Engine is at the machinist and the cab is crated up to take to the body man. Everything is going faster than I thought it would.
1974 Olds Cutlass
Old 08-16-2014, 11:20 PM   #19
gdavis
gdavis's Avatar
cut a X on the top of the rivets with a die grinder with a thin blade. Then take a chestle and knock the tops off of the rivet and then drive the rivet with a punch. It will come out real easy. Are you going to put a standard trans mission back in the truck. If not then you will want to remove the cross member where the transmission was bolted to. It will be in the way for the automatic transmission. the cross member will be right in the middle of the transmission pan. Just a little advice. I already crossed that bridge.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 08-28-2014, 10:39 PM   #20
CParnell
CParnell's Avatar
Had a tough time getting up the nerve to do this next bit.
I looked this thread over and took the plunge. http://67-72chevytrucks.com/vboard/s...d.php?t=123624
I think I would have hesitated less cutting a finger off than chopping into what is really a family member not a truck.
Had to take a breather after that one.
Kinda through it together to get a look.
1974 Olds Cutlass
Old 08-28-2014, 10:57 PM   #21
CParnell
CParnell's Avatar
Also got news today about the 250. After nearly half a million miles it's too worn out to be used. Kinda sad.
So I was thinking about what to do and decided I didn't really want to build an LS based engine. So I had this lying around and thought why not. Will change things a bit and it's gonna be different for sure.
455 Olds
1974 Olds Cutlass
Old 08-29-2014, 06:34 AM   #22
BigDaddyV
BigDaddyV's Avatar
I was holding my breath as I went threw the cut pics...
and when I got to the second section removal, my heart dropped til
I realized you had the back half flipped over.... LOL, (its to dang early)
Awesome work! Looking forward to seeing that Olds engine runnin!
Old 11-05-2014, 11:57 PM   #23
CParnell
CParnell's Avatar
So a few things have changed again. I really need to nail down a plan so I don't spend too much.
I have decided to keep the 455 for my 74 cutlass. I picked up a new straight six. I wanted to keep it 6 cylinder like when I got the truck but I wanted it to be more modern. So I picked up a 4.2L Atlas engine. I stripped a bunch of it today, it's very different from the engines I have built in the past and I'm looking forward to building it. Will have to go turbo on this one for sure.
The 455 and the original 250 six.
And the new 4.2L Atlas.
1974 Olds Cutlass
Old 11-09-2014, 12:48 AM   #24
CParnell
CParnell's Avatar
I dug a little deeper into the Atlas today and I thought you might like to see what it looks like.
1974 Olds Cutlass
Old 11-10-2014, 10:58 AM   #25
mcbassin
Still Learning
mcbassin's Avatar
Very nice job on the frame. You made it look too easy
