Old 06-16-2016, 12:22 AM   #1
BigDan3131
BigDan3131's Avatar
Question Stainless Rod
So as is in my usual way I found something else I plan to change from stock. I need lengths of SS rods threaded on the ends only that are around four feet long. I also need a few shorter ones too.
So what these are for is to do away with the stock hood springs and latch and build hood prop rods like the Willys use except two, one for each side. The latches themselves will be revealed after the truck is done since again I'm doing something different
Where can I get them? Should I try Grainger? 3/8"
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
