Old 08-17-2016, 08:06 PM   #1
Low69CST
Will this radiator support work on my 87?
I found this 1985 with a solid core support. Will this work as a replacement for my 87? My truck has two headlights and a parking light. This truck has one headlight and a parking light.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-17-2016, 08:13 PM   #2
pontgta
pontgta's Avatar
Re: Will this radiator support work on my 87?
Quad lights with quad core support. So if your truck has the same amount of lights it should work.
I did have an uncle that cut into the core support to put in a quad headlight grille. I never thought it look good
pontgta is offline   Reply With Quote
Old 08-17-2016, 08:54 PM   #3
Low69CST
Here is my truck. Sounds like it won't work. What confused me is aftermarket supports say they fit 81-87.
Old 08-17-2016, 09:08 PM   #4
pontgta
pontgta's Avatar
Now, it will work if you want to change your quad light to dual.
On another note... That looks like a sweet ride.
Old 08-17-2016, 09:19 PM   #5
Low69CST
Thank you. It's a good truck, but has gotten very rusty over the past few years. We are in the process of replacing rockers, cab corners, fenders, and maybe doors.
