Heatre Core Matieral
I have heard different opinions on the type of Material or Materials used for the heater cores in our trucks like Copper and or Copper Brass. Any body out there know what they were made of? thanks in advance
Re: Heatre Core Matieral
Someone correct me if I'm wrong but the original cores were copper and brass. Modern radiators (including heater cores) are aluminum or aluminum and plastic.
My original heater core had a leak that according to the radiator shop could not be patched so I had them find me a copper and brass replacement. I think Classic Industries carries copper and brass heater cores, according to a catalog I have. |
![]() Join Date: May 2010
I just bought an APDI/PRO copper/brass heater core from Rock Auto for my A/C truck. It looks just like the one from Classic Industries for about 1/2 the price ($46). I haven't installed it yet.
However, the APDI/PRO for the non A/C trucks looks like aluminum. Last edited by FirstOwner69; 08-26-2016 at 12:55 AM. |
I replaced my leaking original earlier this year with an all aluminum one. It seems to work fine so far. The inlet and outlet tubes do seem a little more flexible than the original however. All the newer cars I've worked on use all aluminum cores, and they seem to last a long time. I would have no worries using either style personally.
#5 | |
My original Harrison unit was copper-brass, as was the repro unit I replaced it with. The repro was much thinner, I should have had my original re-cored (or inspected, it could be fine). In other words, the repros aren't anywhere near as substantial.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Thinner, are saying it being not the (I think) 2 1/2" wide core Original Harrisons, most what I have found in the repop's being in the range of Under 2" wide core?
#8 | |
I think I'll get my original radiator recored also and stash it away as well, when I have more funds. |
Sorry I don't have a measured dimension for either, but to get the retaining brackets to work I had to shim it with a piece of wood, so I wouldn't be surprised if the repro is 1/2 to 1" thinner than the original.
I think what I have read from others here that the width of the repops are thinner and yes a Shimming method is needed to make them work. There's a couple of companies/catalog places that have Copper/Brass Cores but will call and ask what the dimensions are. I have called a few Radiators Shops to see if they can re-core them and all answers so far are NO. So the hunt goes on & on & on.
#11 | |
Your are probably right on the Time Bomb if past owners Only Used Water. Anti Freeze does add a little lubricant to the system I think
Im able to pick one up for 50$ from my local parts store for a 69 GMC 1500.
Do not know the details on it, but its apparently a new reproduction part. |
There is a few places out there that sell repops' but the thing is they don't measure up to a proper fit, Too thin. Original is 2.5" thick & repop's are 2" and under. Repop's typically $45 to some times north of $65
#15 |
![]() Join Date: Oct 2014
I bought this one for my 68, fit perfect and is the same dimensions as original Harrison.
https://www.npdlink.com/store/produc...64-100664.html
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#16 | |
#17 |
No shimming, it was a nice snug fit. I used the gasket that goes around the opening with no problem also.
Make sure your brackets are positioned correctly, they only go one way.
#18 |
