Old 08-25-2016, 10:14 PM   #1
gruveb
Engine fires only when starter is engaged ... Stumped!
I have a 69 C10. The engine and electrical systems are all new within the past 9 months.
The motor will fire when the key is turned all of the way and the starter is engaged. Let off of the starter and it dies.
I replaced the ignition switch.
If I run a wire from the battery to the hot side of the distributor, HEI, then it runs.
I'm stumped. Anybody got any ideas?
The motor is a 383, HEI distributor, all new.
Thanks in advance.
69 Driver - The Analog Truck
gruveb is offline   Reply With Quote
Old 08-25-2016, 10:30 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Engine fires only when starter is engaged ... Stumped!
Thanks in advance.
Where is your HEI getting it's power from?
LockDoc
Leon
Old 08-25-2016, 10:33 PM   #3
teamadams
teamadams's Avatar
check pink wire ign 1. at ign switch should have 12v when key is on and when cranking.
teamadams is offline   Reply With Quote
Old 08-25-2016, 10:33 PM   #4
gruveb
LockDoc
Now that you ask, I'm really not sure. It came with an HEI. I never looked. I'll have to find out.
Old 08-25-2016, 10:36 PM   #5
LockDoc
LockDoc's Avatar
If it isn't already, connect it to the "IGN UNFUSED" on the fuse block....
LockDoc
Leon
Old 08-25-2016, 10:48 PM   #6
gruveb
To be clear the truck ran fine. I drove to work the other day and when I went to go home I had this issue.
Old 08-25-2016, 11:03 PM   #7
gruveb
I ran a new wire from the unfused ignition in the fusebox to the HEI and now it runs fine. I'm still curious as to what happened.
Thanks for pointing me in the right direction!
Old 08-25-2016, 11:46 PM   #8
LockDoc
LockDoc's Avatar
Not sure on what caused your issue. Glad that got you back on the road....
LockDoc
Leon
Old 08-26-2016, 11:50 AM   #9
davepl
davepl's Avatar
I'm going to guess something was wrong/broken/interrupted in your main distributor power lead, but that the +12V override from the starter, which was intended to give points distributors full power during cranking, was still connected.
That way you get ignition during cranking but it quits as soon as you return the key to Run. Sound about right?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-27-2016, 06:15 PM   #10
snipescastle2
snipescastle2's Avatar
Talking Re: Engine fires only when starter is engaged ... Stumped!
I had a similar problem with mine, turns out I had bent one of the terminals on the Back of the ignition switch, that was only allowing it to start while cranking,until I got an inspection and looked a little closer.bent the pin back and everything is fine
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
