Old 08-27-2016, 11:57 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Rochester quad?
What's #1 in this image called? I believe this is the felt gasket that sits between the carb and air cleaner. Also, does anyone know a great source for identifying carburetor parts, including the automatic choke? My 71 was replaced by a manual choke, but I'd like to restore it. The 72 has a automatic choke but may not be complete or working. Pics of a complete choke on a truck would be great. I'm assuming the choke system is the same, big or small block. Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-28-2016, 09:33 AM   #2
71 super
71 super's Avatar
Re: Rochester quad?
The correct carb for 71-72 is a 4mv quadrajet, 7041218 I think is the proper number. It was a auto choke controlled by a bimetallic spring on manifold, not electric. The electric choke came later 76-78 range. The carbs are a little different big block and small, it is based in the lower base plate. The small block carb should have kick down arm while big block will not have the arm.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-28-2016, 09:47 AM   #3
geezer#99
geezer#99's Avatar
Re: Rochester quad?
Try here. Some good pics or diagrams for your choke.
http://www.carburetor-blog.com/free-...epair-manuals/
Old 08-28-2016, 11:50 AM   #4
71CHEVYSHORTBED402
Re: Rochester quad?
The spring must be why the choke on the 72 isn't working. It has a replacement manifold and no sign of a spring I believe the numbers vary. Unless the carb. was replaced prior to 1989, the carb. on the 71 is original. As for the 72 I couldn't tell you. The numbers are:
1971: 7041209
1972: 7042206
Thank you for the response.
Tony
Old 08-28-2016, 12:07 PM   #5
71CHEVYSHORTBED402
Re: Rochester quad?
Thanks. Seem to show everything but the gasket. Looks like it's simply an air cleaner gasket.
Found this pic of a 402 with choke, in case anyone else is interested:
Tony
Old 08-28-2016, 12:21 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rochester quad?
The spring fits inside of the metal housing on the intake. There are a few listed on e-Bay. Everyone lists them as Corvette springs, I guess they think they will get more for them that way....
http://www.ebay.com/sch/i.html?_from...pring&_sacat=0
I think you adjust them by bending the rod that connects them to the choke lever.
LockDoc
Leon
Old 08-28-2016, 12:41 PM   #7
kwmech
Re: Rochester quad?
Air horn gasket
Old 08-28-2016, 01:23 PM   #8
ARC190
ARC190's Avatar
Re: Rochester quad?
You can buy the replacement spring at a parts store. I just replaced mine about 3 years ago and remember it being pretty cheap.
ARC190 is offline   Reply With Quote
Old 08-28-2016, 01:59 PM   #9
71CHEVYSHORTBED402
Re: Rochester quad?
Originally Posted by kwmech View Post
Air horn gasket
At first glance I thought so too, but I'm not so sure: http://quadrajetparts.com/quadrajet-...128_25_39.html
Correct me if I'm wrong, but it looks like the spring mounts to the manifold using one screw. There are two holes in the manifold. One may be for a pin on the bottom of the housing cover.
Tony
