Old 09-24-2016, 05:06 PM   #1
berch 69GMC
berch 69GMC's Avatar
Front springs
I installed 2in drop springs today. Driver side floor to wheel well bottom is 35 in. Passenger side 34in. Looking from the front underneath I see the pass. side is on an angle, driver's side nearly straight up and down. Which is it supposed to be? The height on the pass. side reflects a drop, driver's side looks about the same. I did not measure recently before the install.
berch 69GMC is offline   Reply With Quote
Old 09-24-2016, 05:09 PM   #2
68bowtie
68bowtie's Avatar
Re: Front springs
sounds like one of them didn't sit right in the cross member.
Old 09-24-2016, 05:20 PM   #3
berch 69GMC
Re: Front springs
I twisted each until it was seated on the bottom arm. I think the driver's side I held straight up and down while compressing it. The other side I kind of let gravity influence while I raised it. So I have to change one of them tomorrow, the angle one offers the drop. I drove it ten miles and it drove well. I didn't expect two inches of drop since the former springs were original, but the vertical one was roughly same height as before.
Old 09-25-2016, 11:23 AM   #4
Jose's 69
Re: Front springs
I had the same problem after I put drop spindles and 1 inch drop springs. Checked it last week and now both sides are even. Maybe it just needs to settle. Drive it around a bit. Good luck.
Jose's 69 is offline   Reply With Quote
