Old 02-20-2015, 02:42 AM   #1
Greasey Harley
Greasey Harley's Avatar
2wd NV4500 swap Questions, Help needed
I have searched high and low for information on swapping an NV4500 into a 2wd '68 C10.
I haven't been able to find much.
I am trying to figure out (if it's possible), how to install an NV4500 and maintain the Mechanical clutch and mechanical speedo.
This seems like this would be a solid upgrade, that still lets me use it like a truck.
Can anyone give any advice, or point me to a build thread?
This is the closest I could find:
http://67-72chevytrucks.com/vboard/s...d.php?t=610659
Except, he used a Hydro clutch and electronic speedo.
I'm kind of shooting for "how it would have been" if they offered a 5 speed in 1968.
Greasey Harley is offline   Reply With Quote
Old 02-20-2015, 03:08 AM   #2
SS Tim
SS Tim's Avatar
Re: 2wd NV4500 swap Questions, Help needed
http://67-72chevytrucks.com/vboard/s...14&postcount=3
http://67-72chevytrucks.com/vboard/s...69&postcount=5
93-97 Dodge has the mechanical speedo drive.
http://www.advanceadapters.com/tech-...pecifications/
http://www.high-impact.net/nv4500.htm
SS Tim is offline   Reply With Quote
Old 02-20-2015, 03:18 AM   #3
Greasey Harley
Wow, you sure made that simple, quick.
I swear, I searched numerous times and didn't find that info.
Thank you.
I like to have a solid plan before I go swapping parts.
-Do you have any incite on"throwout bearing and pilot bushing issues to address"?
-Also, Can it just hang there like the 4 speed, or am I going to fab a cross member?
Old 02-20-2015, 03:35 AM   #4
SS Tim
SS Tim's Avatar
Might be best to start with the installation PDF.
http://www.advanceadapters.com/downloads/712550.pdf
It covers everything needed and using a Ford application throwout bearing allowing the Chevy clutch fork to work properly.
As I've posted elsewhere I was first looking at this for a 72 C/30 I had in the late 90's. Basically its a clean swap with the right parts. It bolts up to the bell housing and I was advised at the time unsupported was fine using the existing rear engine mounts on the bell housing. Might want to call them (AA) if you can't find it the provided links.
Old 02-20-2015, 03:49 AM   #5
treveiger
treveiger's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=415769
Here's a thread I started long time ago in hopes of doing it. But my trans was like new so I kept it.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 02-20-2015, 03:54 AM   #6
Greasey Harley
Daaang, You da man.
That is more information than I got when I called Advanced Adapters!!
Go figure.
THANKS AGAIN!!
Old 02-20-2015, 10:07 AM   #7
SS Tim is the data man! If it's in print, he has found it and uploaded it. Book smart can be a wonderful thing.
Old 02-20-2015, 12:28 PM   #8
MidLifer
MidLifer's Avatar
I've had a NV4500 under my workbench since last fall and got sidelined by shoulder surgery. I can't wait to get it installed and drive my truck at 65MPH at a reasonable RPM. I bought the Advance Adapters bell.
BTW if you have the original bell from the trans and it isn't cracked, they sell for decent money on eBay. I got $275 for mine, which went a long way toward paying for the AA bell.
MidLifer is offline   Reply With Quote
Old 09-28-2016, 09:51 PM   #9
Theboatandcarman
good information here.
Theboatandcarman is offline   Reply With Quote
