Old 10-03-2016, 11:00 AM   #1
Hart_Rod
Hart_Rod's Avatar
Rubber bump stop for brake pedal
Does anyone one reproduce these? Thanks in advance.
Hart_Rod is offline   Reply With Quote
Old 10-03-2016, 11:51 AM   #2
bigmac73
bigmac73's Avatar
Re: Rubber bump stop for brake pedal
is that a factory equipped piece, I can remember if my truck has one or not???
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-03-2016, 01:02 PM   #3
Hart_Rod
Hart_Rod's Avatar
yes, it's a rectangle shaped rubber bumper that stops the brake pedal when your foot is off of it. If you have a clutch, it would have one also.
Old 10-03-2016, 01:35 PM   #4
cleszkie
cleszkie's Avatar
Those rubber bumpers are repopped. I bought a set for my Blazer not long ago from the Truck Shop.
cleszkie is offline   Reply With Quote
Old 10-03-2016, 02:33 PM   #5
Hart_Rod
Hart_Rod's Avatar
I found these: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=50
But I think I might just build an adjustable one.
