Power seat wiring/ mounting issues
So I am putting seats out of a 06 gmc in my 64. They are power seats. When I bought them they were not in the truck. I am trying to mount them but the passenger seat is in about the mid position covering up the mounting holes. I'm not terribly worried about having power seat but need to move the seat back to get to the holes. I grabbed some wire and ran a power wire from the battery to the orange wire and black to ground. Once I did so I got some sparking on the ground side once I hooked up the power. I never could get the seats to move. I put my ohmmeter to the two wires and for nothing on both driver and passenger. Am I doing something wrong or what? Any advice or tricks so I can move the seats just to get them mounted? Thanks in advance.
Old member
Ok the seats have to be grounded to the battery by way of a ground wire to the frame. Then a ground on the seat wire and a hot 12 volts to make them operate outside the truck.
The link is to my 99 Tahoe seat install. http://67-72chevytrucks.com/vboard/s...d.php?t=645808
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Power seat wiring/ mounting issues
Thanks for the info.
