Old 10-19-2016, 07:23 AM   #1
jspec25
2wd front crossmember
Can someone post some detailed pics on how the front crossmember attaches to the frame for a 73-87 c10. Just want to make sure I did it correctly.
jspec25 is offline   Reply With Quote
Old 10-19-2016, 02:51 PM   #2
bbbc10
Diggin The SquareLife
Re: 2wd front crossmember
Havent you tried google?
bbbc10 is offline   Reply With Quote
Old 10-19-2016, 11:04 PM   #3
Misled
Misled's Avatar
See if this thread helps.....if not, I some some more before and after pics I can dig out.
http://67-72chevytrucks.com/vboard/s...d.php?t=516817
Misled is offline   Reply With Quote
Old 10-21-2016, 12:52 PM   #4
jspec25
That actually helped a ton. Thank you. Subscribed to that thread also..
Old 10-22-2016, 06:09 PM   #5
SCOTI
SCOTI's Avatar
Really?
There are 6 bolts on the horizontal portion @ the inside of the lower frame rail lip (3x each side) & 8 bolts on the vertical portion of the frame rails (4x each side). Cross measure to get the x-member square before final tightening the hardware.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
