![]() Join Date: Jul 2015
Exhaust Pipes
So I have been thinking of a way to re-do my rusty old exhaust pipes and LMC puts out a kit for a complete system.
Part Number 36-5526 see here: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=157 Has anyone used this product? If so, are the pipes made to use the stock Diverter Valve for Exhaust Gas to heat up the motor? I called them and the guys answering the phone had no clue, and they have no technical specs or drawings. Any info is appreciated. Seems like a decent deal for a complete system on a stock motor. |
![]() Join Date: May 2010
Re: Exhaust Pipes
That kit is made by Heartthrob Exhaust in Minnesota. http://heartthrobexhaust.com/manifolddualkits.htm Call them and ask for Mike. He'll answer any questions you may have. Then shop someplace other than LMC. Try http://www.autoaccessoriesgarage.com...?set-vehicle=1. You can get 15% off with free shipping.
I bought the "stock" mufflers with exits behind the rear wheels. They are not nearly as quiet as stock mufflers were. As I recall you can install them with or wirhout the factory heat riser. I did it without since I have a Holley and GM Performance Parts intake. The system is high quality, but I elected to use band clamps from Summit Racing instead of the included run of the mill clamps. EDIT: My truck is a 69 3/4 ton with an Eaton axle. The kit is not designed for that application. I wasn't aware of that when I ordered. I worked with Mike at Heartthrob and sent him a pattern. They custom bent rear pipe for me at no cost. The stock mufflers are designed to be installed on edge, not flat. That's the way my originals from the factory were oriented also. You may also need to install a new style mini starter for clearance on the right side. Last edited by FirstOwner69; 01-12-2016 at 07:47 PM. |
Old member
Why not just go have it in stalled at a shop?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: May 2014
Re: Exhaust Pipes
I put the Hearthrob kit on my 72 K10 w/350. Was a perfect fit. I bought mine from autoanything.com with a 20% off code
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
Re: Exhaust Pipes
Andy that is the thought, yet I am still way far out until I get a 6.0 setup into my rig.
I kinda have to fix what I have for now. One can only do and dream! |
Re: Exhaust Pipes
Shops are just as cheap sometimes as a kit. I personally like the shops install when everything is a welded connection.
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. ![]() |
I stopped at a local muffler shop and asked about having duals ran all the way out back from the headers to the bumper, he asked which mufflers, i was gonna go with flow masters, he said he had nothing but rust problems with them, told me to buy two stainless steel mufflers and he'd do it all for $275.00! Works for me!
Ben |
![]() Join Date: Dec 2013
Re: Exhaust Pipes
1+ on finding a local shop to have them installed welded instead of generic bolt on system .i have a local guy who lets me stand right next to him and builds it exactly as I want cheaper than any kit .
#9 | |
Old member
![]() Quote:
I had full duals 2.5" from headers back to rear of truck with S/S mufflers. $250.00 out the door. ![]() ![]()
Re: Exhaust Pipes
interested in what way you go
Re: Exhaust Pipes
I had fun doing my own... Ha. I bought the mufflers I wanted, some 2.5 inch pipe and bends and went after it. I have a lift, a welder and a cutter so that helps. You can get creative and run them very nice and tucked up so they cant be seen. It took some time to do it right but that is how I have done most of my stuff.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Re: Exhaust Pipes
Bump, any other ideas for exhaust?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#13 | |
motor exploder
Re: Exhaust Pipes
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Re: Exhaust Pipes
Local shop installed custom bent next to the truck , welded with no hokey clamps all over the place . Clean ,done and have a coke while watching it go together .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#15 |
Re: Exhaust Pipes
I did Stainless Works 3" on mine. Love it. Did a little bit of fab work because I have Blazer tank .
1970 K20 1967 Blown Stepside 2016 Chevy 2500 Duramax 1989 Jeep Cherokee 1995 S-10 2014 Infinity Q-50 AWD 1970 Chevy K20 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=634164 1967 stepside rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=684913 Shop build http://www.garagejournal.com/forum/s...d.php?t=225559 |
#16 |
BlahBlahBlah
Re: Exhaust Pipes
I would definitely ask some of your local car and truck guys who they use. There was a guy here that seemed like he did everyone's ... at least everyone knew who he was. Very reasonable prices, and such a nice tight fit. No ugly pipes hanging down. He's since retired though.
#17 |
Re: Exhaust Pipes
Any other pictures of what you guys have done?
