![]() Join Date: May 2005
Heater core help
Does anyone know where I can purchase a heater core for my PG/250 1966 1/2 ton, with economy heater. I have mine old one out and don't want to go through the hassle of ordering a half a dozen cores to finally get the right size and fit for my truck. a Just thought one of you have done this before and I might benefit from your experience. Thanks for any advice, starting to get cold!!
Re: Heater core help
Ordered one from AutoZone coupe weeks ago fit fine only thing metal tube bracket wouldn't work but wasn't big issue it list for with AC but it worked price was 35.00 best can remember hope this helps
![]() Join Date: Aug 2014
This should help read below.
The heater core in this listing fits the deluxe heater core. I just went to Oriely's and bought a heater core and it was to short. I went back with the Murray number listed below and they pulled it up. I will be in Tuesday. Sounds like Oriely's gave me the standard core the first time http://67-72chevytrucks.com/vboard/s...ht=Heater+core
My current 66 ![]() My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 11-13-2016 at 10:10 PM. |
![]() Join Date: Nov 2012
None of the aftermarket heater cores (Thrift-Air or Deluxe) have inlet/outlet tubes in the right shape. You have to hack the heater box around the tubes to get them in and then the support bracket does not fit either. Without the bracket, all the stress of the heater hoses hanging will be taken by the solder joint of the tube into the core.
These replacements will get you heat but there will be premature leaks at those joints. Typical of aftermarket parts- generally work but not OEM quality. |
Chevy addict
Bought a core from Classic Truck for my 63 standard heater and it fit perfectly
60-66 Nut
Was that for the recirculating heater or the deluxe heater?
![]() ![]() Join Date: Apr 2012
Every heater core I see now is aluminum , any Deluxe heater brass out there ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Chevy addict
60-66 Nut
The deluxe heater core I bought last year is a brass/copper heater core.
Where did you find it Captain ?
60-66 Nut
I ordered it from one of my better local auto parts suppliers. The brand and part number is in this thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=690735
I ordered one at napa for my 65 and was too short so ordered one for a 61 and the fit was great it was aluminum around $50
60-66 Nut
The '60-'63 deluxe heater core is completely different than a deluxe heater core for a '64-'66.
If the first one you ordered was too short, it was likely for the economy heater. Those heater cores are shorter than the cores for the deluxe heaters.
