If a person uses the front and rear-outer floor replacement patch panel, does the rocker backing need to be used? Or does the lower portion of these two afore mentioned pieces take the place of the backing? Also what size and grade bolts are used on the lower a pillar? Thanks for the help in advance.
On the eighth day, he made trucks and saw they were good. |
![]() Join Date: Dec 1999
No, You don't need the backing plates in you are using the floor repair panels.
Thank you Tim!
1969 Custom 30 wrecker
I didn't use them with my 2 trucks. It's just another place for mud and junk to collect and cause rot. I just left the back area open to breath. They are plenty strong too.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
