Old 01-04-2017, 10:54 PM   #1
Curt - TN
1950 Split Hood Rear Center Support Bracket???
I started to put the 2 halves of my 1950 hood together when I noticed I am missing a center rear support bracket.
Does anyone have a picture of what this bracket looks like or even better a source or part number to buy a new one?
I have one bolt broken off, will need to drill that one out.
Thanks,
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 01-05-2017, 12:11 AM   #2
paulspickupparts
Re: 1950 Split Hood Rear Center Support Bracket???
Not sure if repo is available. I have a used one for $25 . Thanks
paulspickupparts is offline   Reply With Quote
Old 01-05-2017, 08:50 AM   #3
Curt - TN
Cool, I will take it. Let me know how we want to handle payment.
Curt
Brentwood TN
1957 GMC 100
Old 01-05-2017, 11:46 AM   #4
paulspickupparts
Ok let me take one off today. About 5 degrees now but should be a balmy 10 degrees by lunch. Thanks
Old 01-05-2017, 11:51 AM   #5
e015475
e015475's Avatar
As a side note, I've been removing a lot of twisted-off bolts on the sheet metal panels on my truck. Drilling them out works, but is kind of time consuming.
What seems to work best is to heat up the fastener with an oxy-acetylene torch until it is cherry red then back it out with a vice-grip. So far it has worked 100% of the time.
e015475 is offline   Reply With Quote
Old 01-05-2017, 11:56 AM   #6
Curt - TN
Thanks, take your time and don't freeze yourself It will be a few weeks before I really need it but am ready for it when you are.
Curt
Brentwood TN
1957 GMC 100
Old 01-05-2017, 11:57 AM   #7
Curt - TN
Thanks for the tip, if only I had not already painted the hood I totally forgot about it before we painted.
Curt
Brentwood TN
1957 GMC 100
Old 01-05-2017, 03:18 PM   #8
paulspickupparts
Here it is . Pm sent with payment info. Surface rust but will clean up nicely.
Old 01-05-2017, 03:28 PM   #9
Curt - TN
Thanks! Money has been sent.
Curt
Brentwood TN
1957 GMC 100
