Old 02-04-2017, 08:09 PM   #1
only126db
Dash Bezel Differences....Will It Fit?
Does anyone know if a '75-77 bezel will fit a 1985?
The difference in price for new is quite substantial.
As long as the screws line up and the gauges line up everything else could be reworked.
Does anyone know or have they tried to make this work?
only126db is offline   Reply With Quote
Old 02-04-2017, 08:31 PM   #2
bbbc10
Diggin The SquareLife
Re: Dash Bezel Differences....Will It Fit?
it will fit but u will the dash for 73-80
bbbc10 is offline   Reply With Quote
Old 02-04-2017, 09:02 PM   #3
TKCR
TKCR's Avatar
If you have the correct dash in the 85 truck, then no.
Old 02-04-2017, 11:03 PM   #4
wilkin250r
wilkin250r's Avatar
I spent several hours at a local Pick-N-Pull one day testing the dashboard swaps.
Now, I have to admit I never looked at the particular combination you're asking, a 75 bezel and an 85 dash, but I DID look at the opposite combo, a 85 bezel and a 75 dash. If I recall correctly, this combo did indeed mount fine, but it left a very unsightly gap around the bezel, just plain ugly.
However, in the many discussions that followed, a few people did say the combo you're asking about, the 75 bezel and 85 dash, looked acceptable.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 02-05-2017, 05:18 AM   #5
only126db
Ok, maybe I will get lucky and my local wrecking yard will have some good pieces, however our local spots are very small.
Old 02-05-2017, 09:41 PM   #6
ray_mcavoy
As wilkin250r said, an 81+ bezel leaves a rather unsightly gap when placed up against a 73-80 dash pad. But when going the other way around, the 81+ dash pad overhangs the top of the bezel enough that it shouldn't look too bad.
Another issue to deal with is going to be the headlight switch location. When GM moved the wiper switch onto the steering column, they also moved the headlight switch up just a little higher on the dash. That will prevent it from lining up with the hole in an earlier year bezel. You could probably fix that issue by drilling a new hole in the metal dash structure and moving the headlight switch back down to the earlier location. And of course you'll be left with an unused wiper switch opening in the older bezel.
ray_mcavoy is offline   Reply With Quote
Old 02-05-2017, 11:24 PM   #7
only126db
An unused opening wouldnt kill me, I have some plastic from stereo kits that I could use to cover something like that. I have a few yards around me it seems, more than I knew of so I may be able to find what I need, but if notit seems I have a good amount of choices.
thx everyone
Old 02-09-2017, 03:54 AM   #8
El Dorado Jim
you need the dash and bezel, have done this swap, put a 70's dash and bezel in a 81 suburban
El Dorado Jim is offline   Reply With Quote
Old 02-09-2017, 08:31 AM   #9
only126db
I think you may have thought I meant leaving the bezel off totally, no, I meant using a bezel that had a slot which was misaligned and fabing up a cover for the slot with some abs.
Either way, the guy brought me the bezel for the truck so I have one...
Saturday is supposed to 37 and I have the day off so I may spend some time in my garage.
