![]() Join Date: Dec 2009
how restore brake booster
Anyone wanna throw out there how to restore a power brake booster on a 67 C10 does not have to be 100% correct. Booster is rusty but solid. Thanks Brandon
Re: how restore brake booster
Believe me. Re-manufactured brake boosters are cheaper and much safer than trying to do it yourself. Even if you could find a rebuild kit out there, which I doubt, by the time you get it done, you will still be way ahead to just get a reman. I just got one for my 71 and it only cost $90.00.
was meaning cleaning up outside as in looks.
![]() Join Date: Oct 2009
Since you're saying restore - I'll assume you mean something beyond just a re-spray with some gorgeous gray primer and then some color. Eastwood company sells a multi-step paint process designed to replicate the Delco-Morraine (sp?) gold/green tint, if that's what you're talkin about. Taint cheap either. Would suck to put $50 in paint into a used booster and then have it go out at 150K miles, just 15 miles down the road.... Unfortunately, most replacement boosters are not coated like the originals. Some companies carry them, like CPP etc.
Dont waste yor time with the paint it is crap... Buy a plated booster from CPP or others and call it good. Tried the paint early on a reman booster and after about 6 months (no driving) it was going south. Bought a new plated unit and have not looked back.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
I agree. Summit sells re-manufactured boosters that are gold (At least the picture is).
1969 Custom 30 wrecker
Some were painted black so if you have that one, real easy to do.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
I sandblasted, primed, and repainted mine with the rustoleum engine paint from Autozone, cleared coated it when it dried and I think it looks great. Not stock but my truck isn't either so no big deal. I was into it about $20.
[IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Burnouts are therapeutic
I blasted my booster and took the right angle die grinder with a scuff pad on it to the master cylinder since it was still on the truck,I then painted it with cast blast spray bomb. I really like the look of the paint and use it on all my rides...... best pic I have
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
How do you sand blast without getting anything in the booster? I just wanna clean up the outside for looks and super tight budget with baby on the way guys! Thanks Brandon
I sanded mine, sprayed it with self etching primer, then Krylon stainless steel, then Duplicolor GS 100 gold. Not a perfect match but close enough until I need a new booster.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Plug the holes good with a cork/newspaper/saran wrap etc. then blast away. Be careful around the openings. If your nervous about blasting it, degrease real good, scuff it up and go that route.
![]() Join Date: Dec 2013
I'm a huge fan of the Eastwood product, which looks great. Yes, it is a tad pricey, but I've redone 2 brake boosters and numerous other under the hood parts.
#15 |
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project |
#16 |
Aren't there rubber parts inside a booster? If so, I'm guessing if the outside is old and crusty, then the innards are as well, right? Something to think about when you go to clean up the exterior of a booster.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
