Old 01-25-2017, 11:24 AM   #1
Anthony14
Need help with steering column turn signal
Hey guys, did a search and couldn't seem to find the info I need. I'm looking at my turn signal assy and am missing what is circled in red. Can I buy this part separately or do I need to replace the whole assy?
Anthony14 is offline   Reply With Quote
Old 01-25-2017, 04:00 PM   #2
jocko
jocko's Avatar
Re: Need help with steering column turn signal
Pretty sure you have to buy a whole ts switch unless you can source that from a part-out ts switch.
Old 01-25-2017, 04:22 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Need help with steering column turn signal
You have a later model steering column per your picture. it has the later model 4 way flasher button.
Here is the break down for the stock column.
You can take the turn signal out of the steering column and see if it has the ring. Are try taking the cap out of yours and stretch the spring in it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-26-2017, 12:14 AM   #4
El Dorado Jim
I think you need the complete turn signal switch,I bought mine from( truckandcarshops)...
El Dorado Jim is offline   Reply With Quote
Old 01-26-2017, 10:01 AM   #5
Anthony14
Thanks guys. Looks like I'll have to buy the whole thing.
