Old 02-18-2017, 10:10 PM   #1
tonys87
driver side wheel sticks out further then passenger.
I have a 64 short box. the driver front wheels sticks out further then the passenger side by almost 1.5 inches. all 4 wheels are the same 15x5.5
Im not sure where to start looking.. makes it look like im running a 15x8 wheel
anyone seen this before?
tonys87 is offline   Reply With Quote
Old 02-19-2017, 01:51 AM   #2
62stepside longbox
62stepside longbox's Avatar
Re: driver side wheel sticks out further then passenger.
My guess would be the offset of the wheels, sounds like the wheel on one side has a different offset than the other side.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-19-2017, 03:17 AM   #3
tonys87
That's what I thought with my old wheel setup. They were trailer type rims.
These are all 15x5.5 3 nub wheels with all the same backspacing.
Old 02-19-2017, 04:23 AM   #4
62stepside longbox
If you are sure they are the same backspacing then it could be that your frame and or suspension components got damaged in a front end crash.
In the original post you didn't specify, is your truck a 2wd or 4wd?
Old 02-19-2017, 05:49 AM   #5
tonys87
2WD. It drives and brakes straight.
Old 02-19-2017, 07:56 AM   #6
tonys87
I measured my lower control arms and got two different sizes in length. Driver side is longer by almost 3/4 of a inch. I'm still not sure which one would be incorrect tho. Can anyone confirm the length?? The passenger side seems to look correct as the wheel looks tucked further in like the rears. But I've also read that the fronts seem to have a wider track then the rears..
Old 02-19-2017, 10:55 AM   #7
AcampoDave
AcampoDave's Avatar
Apart from the control arm measurment deal, is your front end stock?
AcampoDave is offline   Reply With Quote
Old 02-19-2017, 12:33 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
You could also take a look at your radiator support brackets on the frame and see if the front sheet metal is sitting square on the frame. Something is amiss somewhere, sheet metal or frame.
Old 02-19-2017, 01:18 PM   #9
62stepside longbox
Do you have disk brakes? It almost sounds like your drivers side control arm is from a 71-87, the reason I say that is because 71 and up have a track width that is wider by 3/4" on each side.
Some pictures would be helpful.
Old 03-06-2017, 02:18 AM   #10
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 03-06-2017, 11:34 AM   #11
chevy_mike
Never Ending Projects
chevy_mike's Avatar
But that 3/4" difference in from the spindle and brake offset, not the arms. All arms from '63-'87 are the same length. Only difference are the bushing type and ball joints.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-06-2017, 07:44 PM   #12
AcampoDave
AcampoDave's Avatar
^^^Even vans? Just wondering if there could be van parts involved.
Old 03-07-2017, 11:40 AM   #13
chevy_mike
chevy_mike's Avatar
No idea as I have never seen van parts put on a truck nor looked closely at van suspensions.
