Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 10-19-2003, 06:55 PM   #1
low 84
low 84's Avatar
weiand alum intake (egr) and chrome eddy valvecovers/air cleaner
i have a weind action plus aluminum intake for sale. it is emmsions legal, and is egr compatible. its rpm range is from idle to 6000 rpm. its perfect if your wanting to build a high performance engine but still have to pass inspection. weind makes the carb flanges on these a special way that will accept a spread bore or square bore carb with no adapter. so your q-jet, eddy or holley carb will bolt right on. also incleded is a block off plate for the egr port. so if you do not want to use egr or just want to hook it up for inspections you can block it off. this is what i did. this intake sells new from summit for $150. i used it for less than a year and selling it for half the price. $75 plus shipping.
here is a link to the add in summit with a pic
http://store.summitracing.com/partde...57#largerimage
it is a little dirty but i will clean it up some and you can perfect it further if you wish. i will get a pic of the actual intake so you can see its condition but it won't be until next weekend.
also selling edelbrock signature series 14 inch air cleaner and signature series small block valve covers.
i just took these pics off of summit but the condition of mine are good. i can get pics next week end. the air cleaner lists new for $25 and the valve covers for new for $30. i will take $30 plus shipping for the whole set (cleaner and covers).
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
